IT'S Alive (kinda)
Okay my intake project roared yesterday after much diagnosis I need a bettery. But on another note , I am not getting power to the fuel pump, I turned the car on with relay and dummy light, I jumped the relay socket and still no light on the dummy light by the pump. Any suggestions?
Network Native
Check grounds, get a good battery and a battery switch to disconnect when parked. I like the GAMA side post on ebay about $12, put it between ground strap on battery and chassis ground (needs longer bolt and spacer to raise switch up off the body).
Petie3rd
check the fuel pump fuse at the CE panel drop the panel and see if you get 12V from the backsides of the fuse connections, its common for the fuse to be good , but with some corrosion thrown in the power wont go to the pump if this is the case you can remove one of the other no used fuse stations and remove the fuse holder and swap it into the corroded slot this should restore function.
Also check the ground bundle behind the RR quarter panel liner one of these grounds is for the fuel pump iof the grounds are bad the pump wont run. to verify the ground use a test light and remove the brown wire from the pump, connect the other end to the pos side of the battery, the light should come on. Next install the ground and remove the power wire to the pump, connect the test light to ground and the positive wire from the pump, crank the engine the light should come on
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
Awesome thanks for the advise ill do the fuze thing in a bit, first off, the car idles when I ran the pump straight to the battery and tried to start it but I couldn't give it gas like no effort and after a while the the pressure plate for the air intake started slapping hard and it feels like its getting stuck.
Did Ron OK the It's Alive title?
Matt Mariani @the_r_institute Authorized Retailer FIKSE Wheels Mod Italian Wheels Maxilite classic wheels |
Kool
H,mm, I saw that and said to myself, "self, methinks your thread title has been snatched!!"
I guess it's ok, since Jack has an OB, and he seems like a good fellow....and my thread is better!!! Lol..... Jack, perhaps your CE panel needs a refurb...I had to do mine...it's easy....
Ron 1978 5sp (#30) project-Wreckscue, 1979 5sp Euro Project 1982 5sp resto project, 1985 Auto S3 1984 Parts car (the fire car) 1987 s4 (parts, or maybe project) (Yes, I now have 4 project Sharks) |
Yea I'm sorry bro I needed a title and lol wa la lol so I fiddled with the fuze ad looked back at the back of the relay one socket had Colleen out I put it back and well the rest is history,
![]() so now it idles fine but I pull the throttle cable and nothing it just continues idling I thing I still have a vac leak but advise???? Please.
okay guys I have a video of the idol is always stable and now when you give it throttle immediately dies um I checked all the fuel lines everything is pressured Porsche 928 rough idle - YouTube
1979, 928 US, engine in progress. |
Have you hooked this up to a CIS Pressure Gauge yet?
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Okay no how does that work?
Basically one of the MOST important tools for your CIS 928. Here is a link to one as it needs to be specific for CIS and has all the correct adapters.
S & G Tool Aid 33800 Injector Cleaning - Fuel System Tools It hooks up to your WUR (really a pressure regulator) and will tell you exactly what pressures your getting at different temps. The manual gives you the bar and temps. Without this tool, your just guessing.
Okayrt I will look into that. This weekend.
Okay cool ill get that soon, I also noticed I still have ten year old had in it.
I pulled some ne out andit was bad. Yea the tool I will get payday .
