Request: Post-Purchase Inspection - San Diego
Just got my car last week via truck shipment. I originally wanted it to be checked by the shop, but it hit me that I want to go to Sharktoberfest and it would be a good idea to have it checked PRIOR before going on that 2 hour drive.
Anyone in San Diego can swing by and do a post-purchase car inspection? Beer is included
Do note: The car has cigarette smoke, and that smell will take a while to clean if I can clean the smell out. So don't wear your nice clothes.
Old 09-30-2013, 02:35 PM
Network Native
Danglerb's Avatar
Fabreeze can help, SD is a big place so more precise location will help plus model year etc.
Old 09-30-2013, 02:48 PM
Rancho PQ in the deep end.
North of Mira Mesa, south of the 56
1986.5, pretty much mostly stock and have receipts on everything. Fuel lines changed same with TBelt from prior owner.
I dont have a car lift if that means anything.
Going to do the "cleaning" method, but I did buy fabreeze as a intermittent nose saver (scentless version)
Old 09-30-2013, 03:11 PM
Network Native
Danglerb's Avatar
Smoke smell will never be totally gone, but you may be able to get it below your personal level of tolerance.
Who did the belt and fuel lines?
If the tension on the belt is good, and its tracking properly, should be fine to drive it up with just a generic safety check.
Old 09-30-2013, 04:13 PM
I know, I do plan to do full interior exchange so I am not too worried in the long run, its the short run my nose has to suffer.
The prior owner did the fuel lines and belt, and tbelt check.
Well the place I wanted to go to is Greg's shop which is a 2 hour drive, that itself puts me to worry about anything the prior owner forgotten or anything that was installed wrong and a 2 hour drive is LONG.
Hence I rather get a basic post purchase inspection now by a local 928 owner, then when the time comes I will drive it up for a normal full inspection (that is AFTER Sharktoberfest, yes I will be driving it up to it too)
Old 10-01-2013, 08:31 AM
MPDano's Avatar
For starters. Post a bunch of pics of your car. Put your year and color of your car in your signature like we all do. This helps us in all your posts, so we don't need to ask that.
Do you trust what the PO did? I wouldn't unless I personally or someone here knows them. When posting pics, take close ups of the front fuel lines near and under the coolant reservoir tank. Remove the top timing belt cover and take close ups there. Take pics of your 24 pin (opened). Go through all the grounds. If an auto, replace the trans fluid and filter. Replace the oil and filter. Replace the fuel filter. Most likely needs an Intake refresh of all the vacuum and rubber.
86.5 is interference. I would "not" trust that belt unless you can verify it was recently done. Plus, water pump.
Better get moving if you wanna get this all done prior to Shartoberfest in Anaheim.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 10-01-2013, 09:15 AM
I bought it from Shane from Rennlist which he bought from Mark at 928Int after his prior car caught on fire (both in a separate thread) prior to selling he has 3 928s. Here are the ads on the car I bought:
5 speed for sale - Reutterwerk Forums
1986.5 5sp manual w/lsd - $9280 - Rennlist Discussion Forums
more pictures:
Reutterwerk Forums - Shane's Album: Vincents' '86.5 5sp manual w/lsd
Will take pictures when I get home, if I can find the correct areas to take. (first time owning a 928, so it might take a day or two to find the areas that you guys are requesting. Hence having someone come by inspect and show me what to look for and guide me would be quicker... while I can offer a beer and likely breakfast at maybe the Broken Yoke nearby)
I did say he did change out the tran oil to the proper type right before shipping it (the reverse gear has a knotchy problem and it had crappy tran oil beforehand ie likely rust), I did check the engine oil levels and it looks clean. Yet to check the filters, and he said he just recently had a intake refresh. Yet to look at the receipts, will do today.
Need to double check the tbelt if it shifted during shipment on the truck.
First thing I need to do today, is give the car a wash (car was on the lower rack, so engine oil dripped on the car body and who knows what else and it is full of dust from the shipment and the rain they encountered via shipment)
Old 10-01-2013, 10:31 AM
MPDano's Avatar
This is his ad from 12/2012. If all this is true, you should be able to do a cross country trip. I wouldn't worry about and make the 2 hour drive to Gregs shop.
Meteor Gray Metallic with burgundy interior. WP0JB0920GS862698
5 speed manual tranny, with Limited Slip and a Euro 2.7272 gear set in a US 2.20 box which makes 1st thru 4th gears very much like having a 3.09 gear set.
trans shifts are notchy till it warms up.
Sport Seats with non-trashed bolsters
Clean Pod and dash
No stereo, PO removed along with aftermarket alarm system
I've resealed the engine and replaced the vacuum, fuel, and breather lines.
New steering rack bushings (Delrin), pan gasket, motor mounts, brake lines, red painted calipers,
New clutch master and slave and new blue house, new checkvalve.
Smog equipment and cat removed, Ott pipe installed, Porken stub shaft clamps, S300 v 4.0 chipset, torque rings, S4 fuel Reg, 32vlr cam timing, blinkered, rebuilt maf, new CPS, TPS, final stages, cam cover reseal, powder coating on cam covers and intake. 928 Motorsports electric fan upgrade. New water pump, timing belt, cam belt gears OK, tensioner is stock but rebuilt.
928 Specailist "Sharkvent" crankcase breather system.
H4 headlights
True Mileage is unknown, the odo was broke when I bought it. I replaced the odo gear and added in my mileage. Odo reads 227,594. Previous owner stated on carfax that the odo jumped an extra 100k miles when the gear broke. Wear on the pedals indicates 127K mileage.
Wheels and tires in the first three pics do not belong to this 928, if you absolutely have to have them it will be extra as I will need to replace them.
Discount for rennlist members and 928 pacnw club members that have attended any TA events.
If you know the super-secret S3 hand shake I'll give you a further discount.
If you wish to pay for this in Gold & Silver coin I'll lower the price by 10%.
Call any time morning to evening. Three sixty - 273- 8 double seven 4.
This is the GT-S of the early body style.
Old 10-01-2013, 01:21 PM
Oh and sharkvent, Smog and cat is reverted to stock
Still worries me.
Well if anyone is open for breakfast and beer before Sharktoberfest send me a reply
Old 10-01-2013, 01:40 PM
MPDano's Avatar
Well I work at Qualcomm in Sorrento Mesa and pretty much take Mira Mesa blvd to the 15 freeway. I go south so maybe one day, we can meet up on Mira Mesa Blvd near the 15 after my work. There is a "Best Pizza" place right on Mira Mesa. I can check it out real quick to verify certain "important" things were done. Just not crawling on the ground in my work clothes
Thinks like pulling the drivers side top timing belt cover before driving down will ok so I can see the belt.
Have you Registered it yet? Just wondering how it will do in smog.
Old 10-01-2013, 03:04 PM
SanDiego928's Avatar
I like your 928. Shazammm
Mark
1981 928
Old 10-01-2013, 08:35 PM
Pull the ashtray for the center console or one of the side panels. I once had a car that always smelled of smoke even after repeated cleaning. Eventually I pulled the center console and saw a pile of ashes that had fallen from the back of the ashtray. Once removed, the smell eventually went away.
Old 10-02-2013, 04:31 AM
Oh the one next to Autozone, got it. Let me figure out a day (that is not this week)
Got it. Washed my car, and next plan is to take out the dash+center console for cleaning
Old 10-02-2013, 04:04 PM
MPDano's Avatar
Pull Dash for cleaning? What for? That's an intense job. Ask me how I know.
Old 10-02-2013, 04:13 PM
Ash tray + burn marks + lingering smoke + prior owner is not a smoker = cleaning time
Plus want to fix the odo, and clean electrics and double check connections (aftermarket alarm was removed before, and so is the radio, so I really not too trusting on the connections under the dash)
Old 10-03-2013, 11:05 AM
Can we do this, meet up at the pizza place eat then I drive you to my house for the inspection then drive you back to Best Pizza Place?
Nope not registered yet, hence me scared of driving it in broad day light (early morning and late night I might be able to pull it off but kinda cant inspect it due to lack of light)
Old 10-07-2013, 03:38 PM
After reading Leo's post above, this car is ready to go cross country per the 12/2012 ad.
Seems you need a smog and to register your nice 928. Then up to Anaheim on the 19th.
Mark
1981 928
Old 10-07-2013, 08:05 PM
MPDano's Avatar
I'm not volunteering to look at you car to eat. I just chose that place since I see it on my way home. Get a day pass from AAA or the DMV, just tell them your going to bring it to a repair shop. You can can request a couple passes for different days. request the 2nd for a day you will smog it.
I'm just going to verify a few key areas so we can make sure it'safe to go to Sharkfest or Gregs. We'll let Greg do the official PPI, especially anything under the car, which is really not much unless your experiencing leaks.
Old 10-08-2013, 05:09 AM
Ill see what days I can actually get to the DMV.
Old 10-08-2013, 08:46 AM
MPDano's Avatar
Get AAA, it's cheap and don't forget your driving a 30 year old or close to car.
Old 10-08-2013, 09:47 AM
