so many lube options !
so, I have an 86.5 928 up on stands and I want to change all lubes. With that said, I've searched quite a bit for proper lubes on forums and there are a lot of opinions
I just want to keep it simple but I wont cheap out this is a very nice car ,in nice shape and I just want to do the right thing. Any help would be greatly appreciated. 1986.5 5 speed LSD Thanks, Justin |
Some like the 15W40 oil. Depends on your operating environment. I changed out all my fluids when I got the car. Dexron in the Auto trans, also drained the Torc converter. If you do the trans axle, take the FILL plug out first. Some had a problem getting it out after draining the unit. I believe the PS also takes trans fluid. Coolant, drain all out and replace with good anti-freeze and distilled water. As for fluids/oils, just stick with well known brands and you should be OK.
1986 928S 32 valve engine All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires. Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster |
Thanks Harborman,
I'm located in central NH, probably same climate as Mich. But wow does this issue get involved, a lot of different opinions. At first I assumed I would stick wit the info in the owners manual, but made the mistake of research. Thanks for your help. I want to drive now that we have no more snow banks! |
