DME Switch Adjustment with Chips
Hello,
I would like to know if anyone here has experience with the best combination(s) of DME switch settings and the Lindsey Racing Chips... I am wondering if it makes any difference after installing these chips, and whether I should worry about detonation in the state of CA with 91 octane fuel based on the setting. What sort of effect does the adjustment of timing and fuel have? Since there are 8 different settings, guessing seems like a bad idea. Educated Thoughts? Carlos |
winter-hater club member
i am betting that the switch has been obviated with the new chips. for specific answers you will need to talk to the folks at lindsey racing.
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
Regards, Russell |
Russel to your knowledge would that be true of most chips pruduced in the past?
I am going to do some testing on mine to find out, but I don't know what chips they are yet. I willl test using my EGT and a timing light to see.
Sid splitting my obsessions with a crow bar. 87 DD Black 951 Holset HX40-35 custom garrett turbine, Ford MAF, Rogue tuned,SLM stroker, best ET 11.4..best mph 127 |
Your mileage may vary... Regards, Russell |
Thanks.
I got the FQS stuff down pretty good as I use it a lot on the ol 44 s/c car for both fuel and timing. I am going to check this tonight. Soon I will be sending you an email regarding an E85 map setup and probably a maxtune order for the 51.
