All Spooled Up
Wishful thinking (mega-flow air filter).
Here is a pic of the K&N filter that came with the MAF conversion, and the one that I wish I could use (#0248). It obviously won't fit where the other one is, and I don't have the heart to enlarge the hole going into the fender to 7 inches diameter.
>gray 89 951S - K27/8, MAF, 3" intake, 3" exhaust w/separate waste pipe, 55# inj, late cam; >red 87 924S - chip, K&N, punched-out cat&muffler >black 80 924 - (sold) >maroon 77 924 - auto (sold) |
Perhaps you can try shortening the pipe?
BTW, what type of coolant expansion tank cap is that?
'87 951: 217 hp @ 12 psi Candy Black/Black |
All Spooled Up
You mean that chromed piece of pipe sticking out past the afro-engineered hot air blocking wall? That is the MAF sensor, and it would not be practical to try to relocate it anywhere else. Even if you could, placing the big cone filter in it's place would not allow the left headlight to retract all of the way down (the one there now barely allows it).
The coolant expansion tank cap is the lever-vent type. When I replaced the cap, I opted to pay the extra buck, or what ever it was, to get one with the lever. The reason it appears to be slightly up from the normal position, is that for purposes of taking the picture, it is being used (along with the ratcheting wrench) to hold the big air filter from rolling down the sloped tank. Although I rate myself to be pretty good (naturally) at figuring out how to do some not-so-easy-to-do things, I don't see any possibility of using the 0248 filter in this particular application, due as usual with these cars, to space considerations. Pretty much all of the extra space in the engine compartment has already been accounted for, by the manufacturer.
Super Moderator
this is the best filter i've found for this location;
http://forums.pelicanparts.com/porsche-944-turbo-turbo-s/420727-k-n-x-stream-intake-filter.html
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!) |
