Go Back   Pelican Parts Forums > Porsche Forums > Porsche 944 Turbo and Turbo S
Best place to mount manual boost control?
Any pictures of manual boost control mount point? What is the best route to run the lines through the firewall? 1986 944 turbo thanks
Old 07-13-2011, 08:43 AM
On Boost
Paulyy's Avatar
i'm guessing you want it in the cabin? you can also but it infront of the intake manifold. that's where mine was.
86 952 GTX3076R, M-Tune, eBoost 2, CEP/JME cam, CEP head.
Old 07-13-2011, 03:36 PM
yes would like to have it within reach but dont want to drill holes in the firewall for the lines...
Old 07-13-2011, 09:01 PM
That Guy
Techno Duck's Avatar
There are 1 or 2 factory grommets on the firewall, not sure if they are on all model years though. Same for going into the cabin from the battery tray.
I have the boost controller mounted in my glove box. Easy to adjust, but not too easy if you get what i mean .
No pics of the lines going through the firewall, but if memory serves right there is one right behind the cam tower hoist ring.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 07-13-2011, 09:42 PM
hello yes tech i was thinking inside the glove box will check on the grommets on the fire wall thank you
Old 07-14-2011, 09:33 AM
You can also put a hole through the rubber grommet in the DME harness and feed through there. I heated up a iron and jabbed it through. Just don't hit any wiring.
This made it easier to hide the extra vaccum lines or wiring.
Old 07-14-2011, 10:03 AM
89-944NA's Avatar
Location: In a dumpster behind Albertson's in Los Angeles County
Send a message via Yahoo to 89-944NA
Follow the vacuum line that goes to the KLR, use the same hole and put your MBC in the glovebox...you don't even need to drill a hole, just remove the vent that is just inside the glovebox (on the left side), and use that to mount the MBC
1989 944 NA Glacier Blue - SOLD IT
1989 944 S2 Alpine White T-Boned (totaled) by a lady dressed in a CLOWN costume (RIP ) Apr 89 - Mar 08
1988 944 Turbo S Silver Rose Metallic, K27/6, Vitesse MAF, Tial 38mm DP WG
Semper Fi
Old 07-14-2011, 07:48 PM
