notabot's Avatar
HVAC/Idle/Stalling Issue (1995)
Hi Pelican People,
I’ve already bothered other forums about this, but I’m trying to cast a wide net here. I live in Texas and we’re getting into those scorching summer months.
My 1995 Porsche 911’s idle stays around 750 RPM, but it will drop to <500 RPM when the AC is turned on. Sometimes it’ll even die/stall when coming to a stop, but only when the AC is turned on.
The previous owner installed some Fabspeed mods; removed the cats (O2 sensor still installed), Fabspeed exhaust, Fabspeed airbox cover, Cyntex performance chip. The car has a dual mass flywheel.
What could cause this? What’s the most cost effective way to approach this problem?
Old 05-21-2020, 08:12 AM
My 95 did the same thing a few years ago. I too have a fabspeed setup but with a Steve Wong chip. Took the ISV out and cleaned it. That cured my problem. Good place to start if you haven’t done it yet.
Old 05-28-2020, 05:43 AM
I would thoroughly clean the ISV (very easy) and then try to get your hands on a stock chip.
Andreas
1995 993 Coupe, Polar Silver / Black
2014 Audi A4, Monsoon Gray / Black
2002 Toyota 4Runner, Dorado Gold
2001 Toyota 4Runner, Dorado Gold, 604,XXX 1-owner miles
1998 Toyota 4Runner, Oxidized, 5-speed
Old 05-29-2020, 03:46 PM
+ reset the ecu...
https://rennlist.com/how-tos/a/porsche-993-how-to-reset-ecu-378258
Old 06-03-2020, 08:21 AM
