911Obbie's Avatar
92 964 tip:ABS light, speedo out, tip manual out, spoiler light
So - have owned this 92 targa tip since 2000. Rebuilt the engine 6 yrs ago.
This happened 3 weeks ago:
ABS light came on
Speedometer quit working
Tip on the manual side switches back to automatic after 2 minutes, and
Spoiler only works manually.
I also have the Durametric software for this car.
TIP ECU had not faults.
Motronic ECU 1 minor fault (it has never like my chip upgrade since 2003).
Most of the faults were AC/heater flaps issues.
Jumped on the forums here and Rennlist.
Cleaned front left sensor and replaced ABS relay with hew one from our host.
Everything above still the same.
I know the ABS unit has relays that may be suspect.
The car runs very powerfully since the rebuild, but this is annoying.
Any thoughts on what do to do next?
Thanks for any help!
Old 10-09-2021, 09:41 AM
Abs supplies speedo , speedo supplies spoiler .
So concentrate on abs system .
Start with sensors , and power .
Old 10-09-2021, 02:44 PM
911Obbie's Avatar
Thanks. Good summary of much of what I've been reading.
Will advise of progress and solutions for benefit of the forum.
Old 10-09-2021, 04:25 PM
group911@aol.co's Avatar
Correct. If I remember right, the left front sensor is where it's read from.
Thanks,
Bob
group911@aol.com
Old 10-10-2021, 07:18 AM
911Obbie's Avatar
Thanks.
Starting the process to work backwards from ABS sensors and connectors. Likely have to have codes checked re relays and FCU if sensor signals and signal paths are good.
Old 10-11-2021, 12:27 PM
ABS light came on
I have the similar problem occasionally. ABS light up and buzzer sound, Speedo meter quit working. Finding what to look up first. Hope you have clue.
Old 10-14-2021, 05:48 AM
911Obbie's Avatar
I was very methodical wth the engine rebuild. Same approach here.
Was hoping the ABS relay change out would be the simple fix.
Will test ABS signal paths first.
Then power.
Then get codes read ie FCU and ABS unit relays.
If all is good then I've got to look at speedo.
Will keep all updated.
Old 10-20-2021, 06:43 PM
Then power.
- Speedometer pin4 goes to R24 pin5 (FCU for control unit)
- R24 pin6 (input signal) goes to Wiring Diagram grid C35
- Grid C35 refers to ABS control unit pin17. (FRONT LEFT)
1993 964 C2 still makes me smile
Retired and work as needed as a pain in the **s.
Old 10-20-2021, 07:25 PM
Updated my situation: My problem solved by replacing the R34 relay.
Old 11-03-2021, 12:00 AM
911Obbie's Avatar
UPdate-
No signal from the left front sensor with a DVM.
Then did a brake test - 60 MPH, hits brakes hard..... front left wheel locked up.
Will procedd from here.
Thx for inout.
Old 11-16-2021, 06:21 AM
That sensor is easy to pull and inspect. It could be as simple as a bunch of metal fragments attached since it's magnetic.
UPdate-
Thx for inout.
Thanks,
Bob
group911@aol.com
Old 11-16-2021, 06:27 AM
911Obbie's Avatar
I pulled, cleaned and reinstalled the sensor few weeks ago. It was pretty BAD. I didn't check the output at that time. Have ordered one from our host.
Old 11-16-2021, 06:31 AM
I think you can also swap left to right to quickly assess the issue
Thanks,
Bob
group911@aol.com
Old 11-16-2021, 06:35 AM
911Obbie's Avatar
Thanks Bob.
Will keep working my way up the signal chain.
Do you know if this left front sensor feeds the entire signal path - ABS, frequency counter, speedo, tip ECU and spoiler? and, does the FCU have a code if in fact it's the culprit?
What's odd when I had it out was the Tip worked for 2 minutes then stopped. Speedo did not, spoiler did not and ABS remained lit the whole time. 120 second each on/off . ??
Old 11-16-2021, 03:42 PM
I don't know if it feeds all that but I'll bet Ian knows.
Thanks,
Bob
group911@aol.com
Old 11-16-2021, 05:59 PM
It’s easy enough to check all 4 wheel sensors with a meter .
Unplug and insert test leads , and read ohms .
Should be around 1k , then spin hub slowly to see the reading move .
Another way is with a continuity beeper , should beep when plugged in but go on/off when hub rotated slowly .
Bear in mind pad sensor is simply open/closed so make sure you are connected into the right plug !!!
I will clear space , and pm you my email as will be easier .
Old 11-20-2021, 09:01 AM
Thanks Bob.
Wheel sensor goes to abs , abs goes to converter then speedo , speedo goes to spoiler .
When you say tip worked then stopped , you mean worked in manual then stopped ?
Did it fall into 3rd gear ? (Limp home mode)
Simple things first , is your battery good and fully charged ?
It’s pretty much a must for troubleshooting on any “modern” car …
Did you do a hard reset by disconnecting battery for 20mins +
Old 11-20-2021, 09:07 AM
911Obbie's Avatar
Pic looks familiar with the leads in the ABS connector..... nothing. Waiting for the new one from
our host.
Re Tip not working: I can shift through 4 gears Tip mode, then after 2 minutes, the Tip gear indicator light on speedo goes out and drops to 4th. Not limp home mode but fully automatic. And runs great in that mode. First time i thought it was limp home mode (wasn't), pulled over. turned off, waited couple minutes, started back up and went through all 4 in Tip mode then back to only auto mode after couple minutes. Quite puzzling.
New battery last year. Holds strong charge ( I keep a bat/alt monitor that plugs in to cig lighter for occasional check . Replaced alternator 2 years ago.).
I have a battery disconnect because I sometimes don't drive for a couple months (but garage kept and does not see rain; it's also in most of the winter). So, yes it gets a hard reset regularly.
Appreciate any thoughts and help as I start working up the signal chain.
Old 11-20-2021, 05:47 PM
If you definately have a sensor that tested bad , let’s wait to replace that before we work up the signal chain .
The front 2 sensors are the same , should you wish to swap whilst waiting for a replacement .
Another quick check while you have a repeatable fault , if you can please try to pull over and starting in neutral after a tip fault .
The good news is , you have a repeatable fault !!
Much easier to troubleshoot than an intermittent fault …
Next step would probobly be the speedo converter , as that takes a wheel speed sensor and converts to speedo signal . Speedo then controls spoiler through spoiler control unit .
If the converter is bad you lose speedo , and everything it controls .
You should find the speed signal converter in the front fuse box iirc
Old 11-20-2021, 06:49 PM
Ian
What does the neutral start tell you?
Thanks,
Bob
group911@aol.com
Old 11-21-2021, 10:18 AM
