Rick Lee's Avatar
Can I remove just my tranny?
I'm in disbelief, but a guy on Rennlist (he may be here too) said you can do a 993 clutch R&R without removing the engine. How in the world can this be? I'm dying to know if this is true. If it is, I'll be doing the RS kit much sooner. Please explode this myth or confirm it.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 10-01-2003, 08:48 AM
Bandwidth AbUser
Jim Richards's Avatar
I think a special supporting rig for the engine is used to do the tranny-only drop. I vaguely recall this being discussed on Rennlist a year or so ago.
Jim R.
Old 10-01-2003, 09:26 AM
Ag Bull8's Avatar
I've been told several times that on a 2WD 993, you don't need to drop the engine to do tranny work, however, I've never done it myself. The people who tell me this work on 993's.
If you can be patient, I may be doing a tranny swap on my 2WD 993 and using this method...
Kim
95 3.8L Carrera "Yellow Zonker"
91 1.6L Spec Miata "Spec Piņata"
Old 10-01-2003, 10:08 AM
Hi Richard,
I've done it before on a 964 C2 turbo. It seemed quicker than removing with the engine as there was alot less disconnection work. I guess doing it on a 993 should not be too different.
I did not have a tranny rig but just regular stands seemed to have done the job holding the engine. The gearbox needed to come out at a slight angle downwards. I also loosened the engine mounts beforehand just in case they get damaged.
Getting it out was not difficult. Getting the gearbox back in was a bit harder. A transmission jack helped things but still wasnt easy mating it with the engine because of the alignment of the 4 studs and the shaft, hence using a proper clutch alignment tool is a must.
Good luck.
Old 10-02-2003, 10:39 AM
Rick Lee's Avatar
Wow! I'm amazed. I guess it's almost time for that RS clutch kit then. Did you change the flywheel too? If not, do you know whether that is doable with just a tranny drop? And how long did it take you?
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 10-02-2003, 10:45 AM
marcesq's Avatar
Richard if the tranny is out the flywheel is completely accessable.
'94 CMC Firebird Trans Am
'86 951 LS1 (C-2) Gone
'77 911 3.2 (C-1) Gone but not forgotten.
http://www.pelicanparts.com/MotorCity/marcesq1
http://www.youtube.com/user/958Fan#p/u
Old 10-02-2003, 07:36 PM
Hi Richard,
As marcesq suggested, the flywheel was doable without difficulty. The job should have taken less than 12 hours for someone not so skilled like myself. However I had to add a few hours on top because I stripped the heads of a clutch cover bolt and a flywheel bolt, which was a real pain in the bottom.
Also remember to replace all bolts and the flywheel seal while you have the chance to.
Regards
Old 10-02-2003, 11:37 PM
marcesq's Avatar
C.P. you have noooooooo idea what you just started
Old 10-03-2003, 06:42 AM
Rick Lee's Avatar
Originally posted by C.P.
Hi Richard,
Oh, that could never happen to me.
Hey Marc, you busy next weekend?
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 10-03-2003, 07:55 AM
Sorry Marc, I didnt know I was going to get you into so much trouble.
Good luck guys.
Old 10-03-2003, 08:27 AM
marcesq's Avatar
October 18th . . . . get a lift and line up a 5' tranny jack.
Old 10-03-2003, 10:19 AM
Rick Lee's Avatar
I'm kidding. My clutch is fine. When it starts to go, I'll methodically round up parts and docs for this job. You know my life's mantra - if it ain't broke....
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 10-03-2003, 10:38 AM
hallo
I have done that a few Times , it is very easy ,but you need a Tranny Jack .And leave the Clutch slave on the line and unhook it with the 2
13mm nuts from the Tranny . that way you dont have to bleed the cluch .
Harald
Old 10-11-2003, 04:23 PM
turbo dreaming
So do you only need one transmission jack? Or do you need another tall jack to support the engine as well?
Guess what I'm asking is does the engine need to be lowered slightly to let the transmission come out at an angle?
Any detail would be greatly appreciated.
Princeton Wong
96' 993 Carrera 2...Turbo
As seen on MaydayGarage: http://goo.gl/mGmZB
In Excellence #191: http://goo.gl/BjOsn
Old 10-13-2003, 08:50 AM
hallo
take a woodbeam standing upright ,than you lower the Tranny jack about 4 inches and rest the Engine on the woodbeam .
Harald
Old 10-13-2003, 11:28 AM
turbo dreaming
Hi Guys,
Thanks for the help.
Got my tranny off in about 2.5 hours. I'll post pictures once my entire clutch install is done
Princeton Wong
Old 10-26-2003, 09:16 AM
maxnine11's Avatar
thanks in advance Princeton!! we could use some DIY threads/pictures around here!
max
Old 10-26-2003, 10:13 AM
Posted this on Rennlist as well, but figured I might get some response from this thread...
My clutch has a sort of on/off feel to it, so I figured a nice winter project would be to remove the transmission (only) and see what kind of shape it's in. I couldn't find specific diy instructions, but it looks fairly straightforward. Thanks to the C4, the tunnel in front of the transmission looks like I've got plenty of room to move the tranny forward (away from the engine) to disengage the input shaft from the clutch. Removing the starter looks challenging, but doable.
I do have one specific question. Do I have to remove the oil line shown below? And if I do, does the oil have to be drained first? If so, I may wait and do this on my oil change cycle next summer -- there's $40 worth of Mobil 1 from July in there.
Thanks,
Chris.
'95 993
Old 11-16-2003, 06:47 AM
turbo dreaming
Chris- No need to remove the line. It actually pulls down below the level of the suspension crossmember once the clamp is taken off. Check out my post about the Tilton clutch in the 911 forums. There is a write up I just did about the tranny drop.
Princeton Wong
Old 11-16-2003, 09:12 AM
