964 and 993 Engine Questions
Hey everyone,
Need some answers for the following questions, thanks! 964 Engine idle speed? Type of spark plug and gap? Timing? Valve clearance measurement? Air filter model number? oil filter model number? fuel filter model number? 993 Engine idle speed? Type of spark plug and gap? Timing? Valve clearance measurement? Air filter model number? oil filter model number? fuel filter model number? Thanks, Brian Minson Publisher/Editor 9, The DIY Porsche Magazine http://www.9magazine.com |
Sounds like you need to buy some Porsche manuals.
Have Fun Loren Systems Consulting Automotive Electronics '88 911 3.2 '04 GSXR1000 '01 Ducati 996 '03 BMW BCR - Gone |
I need more info on the 964s and 993s. I have all the FWS manuels for the other models.
Might just have to do that soon! ![]() Brian Minson Editor 9, The DIY Porsche Magazine http://www.9magazine.com |
Bandwidth AbUser
Brian, unless someone provides the info first, I'll try to get you the 993 info when I'm back at home this evening.
Jim R. |
964
Engine idle speed? 880 + or - 40rpm 1000 +- 50rpm on Turbo 3.3 950 +- 50rpm on Turbo 3.6 Type of spark plug and gap? Bosch FR 5 DTC 0.8 + or - 0.1 mm Timing? 0deg + or - 3deg at 880rpm on Turbo models intake opens 4deg. bf TDC, intake close 56 deg. bf BDC, exhaust opens 44 deg. bf BDC, exhaust closes 4 deg. bf TDC on M64/01 & M64/02 intake opens 3 deg. bf TDC, intake closes 37 deg. bf BDC, exhaust opens 27 deg. bf BDC, exhaust close 5 deg. bf TDC on M30/69 intake opens 2 deg. bf TDC, intake closes 54 deg bf BDC, exhaust opens 43 deg bf BDC, exhaust closes 3 deg. bf TDC on M64/50 Valve clearance measurement? intake 0.1mm (0.004in) exhaust same Air filter model number? oil filter model number? fuel filter model number? More to come soon
'87 911 3.2ltr Cab. ROW (sold )'90 964 3.8 ltr C4 Coupe (P-Dealer built, track prep'd, sold ) )OMYG..I'm Porscheless Last edited by expat; 01-16-2004 at 10:12 AM.. |
Bandwidth AbUser
OK Brian, this is what I have -
993 N/A Engine idle speed? 800 rpm +/- 40 Type of spark plug and gap? Bosch FR 6 LDC 0.7 +/- 0.1 mm Bosch FR 5 DTC Beru 14 FR-5 DTU Timing? 1 mm valve lift, zero clearance: Intake opens: 1° BTDC Intake closes: 60° ABDC Exhaust opens: 45° BBDC Exhaust closes: 6° ATDC Valve clearance measurement? n/a - Hydraulic lash adjustment Air filter model number? 993.110.327.00 oil filter model number? 993.107.203.03 & 993.207.201.02 fuel filter model number? 928.110.253.04 993 Turbo Engine idle speed? 800 rpm +/- 40 with A/C on: 880 rpm +/- 20 Type of spark plug and gap? Bosch FR 6 LDC 0.7 +/- 0.1 mm Beru 14 FR-6 LDU Timing? 1 mm valve lift, zero clearance: Intake opens: 12° BTDC Intake closes: 117° BTDC Exhaust opens: 124° ATDC Exhaust closes: 5° ATDC Valve clearance measurement? n/a - Hydraulic lash adjustment Air filter model number? same? oil filter model number? same? fuel filter model number? same?
Jim R. |
964 M64/01
IO 4° BTDC IC 56° ABDC EO 45° BBDC EC 5° ATDC 993 M64/05 IO 1° BTDC IC 60° ABDC EO 45° BBDC EC 5° ATDC 993 M64/21 IO 0° BTDC IC 59° ABDC EO 47° BBDC EC 5° ATDC 993tt M64/60 IO 12° BTDC IC 63° ABDC EO 56° BBDC EC 5° ATDC 964t 3.3t M30/69 IO 3° ATDC IC 37° ABDC EO 27° BBDC EC 5° BTDC 964t 3.6t M64/50 IO 2° ATDC IC 54° ABDC EO 47° BBDC EC 3° BTDC
