PITA screenwashers...
Hello fellows,
Just changed the screenwasher pump cause the screenwasher jets didn't do anything... Fit the new pump and guess what : screen washer jets still not working but all the fluid is going into the little 'intensiv reinigung' tank ! Seems to me that the normal tubes from the regular screenwasher pump are blocked... Looking for those tubes and I can't find them ! From the big watertank in the left fender, the tube goes into the luggage compartiment but then I can't follow it... Does anyone has pics of the route this tubes run through the luggage compartiment ?? (not the ones from the 'intensiv reinigung' tank) Thanks, dick911 |
Near the washer jets, you should find a one-way valve next to each. Frequently, those valves clog.
Try replacing them. AFJ
Es geht nicht darum wie schnell man faehrt, sondern wie gut man schnell fahren kann. Ihr Brunnen der nutzlosen Porsche Information |
OK, thanks !
