Hi Bill,
I have a '92 964 C2 that had original shocks and springs. I wanted to lower the car (and improve handling) so I had my local shop install ROW M030 springs with Bilstein HDs. Was aligned and corner balanced etc. Problem is that I don't think the car is even 1/8 inch lower. Was expecting 3/4 inch to 1 inch based on online posts. Is there any way to adjust the ride height? Can the shocks be installed in a way to compress the springs more, or did I just get the wrong springs for lowering?
Many thanks for any advice you have.
Jeff
Old 04-26-2013, 06:48 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #161 (permalink)
Bill Verburg's Avatar
Originally Posted by jeffreyallen View Post
Hi Bill,
Jeff
W/ the exception of RS, none of the 964/993 factory suspensions are designed w/ lowering in mind.
here is a front and rear 993 M030 shock spring set.
The front gas a very short set of threads that can be used for corner balancing, the rear uses different thickness shims to adjust height a small amount.
Bill Verburg
Old 04-26-2013, 03:43 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #162 (permalink)
Science is NOT optional
rbogh901's Avatar
Originally Posted by Bill Verburg View Post
Exhaust
964 uses a very inefficient x-over system, the right bank cylinders merge and x-over to the left where they further merge w/ the left bank cylinders
Hi Bill, Do you have any info regarding the 964 Cup car manifolds/exhaust? I was under the impression that did not use a x-over/merge.
PCA member since 1993
Old 04-29-2013, 01:13 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #163 (permalink)
120 HP/Liter is all I ask
Mufflers (8 & 9 in diagram) are straight through pipes on 964 Cup
Old 04-29-2013, 02:19 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #164 (permalink)
relative flow
#6 cat 442
#8 muffler 462
#9 muffler 396
weight per Perlet
OEM 964 exhaust
12 lbs left
16 lbs rt.
13 lbs cat
41 lbs total
Bill Verburg
Old 04-29-2013, 05:02 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #165 (permalink)
Hi Bill, I have 92 964 c2 cab with stock shocks and lowered springs. I wanted replacing broken front sway bar (20mm) and drop links to 993 sway bar and 993 drop links. Is it possible? What is difference between 964 and 993 sway bars? Many thanks for answer.
Gints
Old 10-02-2013, 12:17 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #166 (permalink)
Bill et al,
Great informative thread!
I recall seeing somewhere an electric power steering mod for the 993.
Anyone aware of how to do this?
Electric Pump located in front boot, to supply pressurized fluid to the OEM power steering unit?
Or true electric assist power steering rack?
Anyone have information regarding such an application?
Thaks,
John
JT
Old 11-06-2013, 12:45 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #167 (permalink)
Originally Posted by JohnnyT View Post
Bill et al,
Thaks,
John
I have not done this, but people have used a 997 Cup electric power steering oil pump with the stock rack. This requires wiring and plumbing the pump into the front of the car. This allows removal of the engine driven oil pump and lines going to the back of car.
"It all started when I began looking around and just could not find my dream car. So I decided to build it myself” - Ferry Porsche
Old 11-06-2013, 08:13 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #168 (permalink)
As Bob says a 996/997 Cup electric pump, plumbed into the stock rack
It looks like this
As an aside, anyone else notice several missing pages in this thread?
Bill Verburg
Old 11-07-2013, 02:10 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #169 (permalink)
CupCar, Bill,
Thanks for the reference.
Here is another photo of Power Steering Pump!
Looks good!
Looks like Air Jack behind the pump.
JT
Old 11-08-2013, 10:29 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #170 (permalink)
Oleg Perelet
Pump itself does not need to be strictly part from 996/997 cup. There are MB, Toyota etc pums that are as good. As far as I understand pump should be from 2005 or earlier car, later cars have CAN bus connector, also some pumps from later cars have variable assist pressure.
Pre CAN bus pumps fall in to 2 cathegories -
1. constant load pump - works all the time at full load.
2. variable load, pump pretty much idles when steering is straight, when steering is turned pump has senses it via liquid pressure switch and ads rpm's.
Type 2 pumps do not create alternator/battery load while steering is straight.
There are good threads in 928 land about conversions.
Oleg
Old 11-08-2013, 08:10 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #171 (permalink)
I'm getting really curious about this
some times I look in this thread and find 9 pages others times only 6
How many pages do you guys get?
Bill Verburg
Old 11-09-2013, 05:51 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #172 (permalink)
Today 9 pages
Old 11-09-2013, 06:46 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #173 (permalink)
Originally Posted by BimmerDob View Post
Today 9 pages
Really strange, this is pg 6 today on my screen
Bill Verburg
Old 11-09-2013, 08:08 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #174 (permalink)
e3photo's Avatar
I'm getting 9 pages.
Emerald
'88 911 coupe, Laguna Green Metallic (sold)95 993 Aventurine Green(sold)
97 993 C4S Vesuvius
Old 11-09-2013, 04:22 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #175 (permalink)
rbogh901's Avatar
Kewl!
9 pages to here today.
Old 11-09-2013, 08:48 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #176 (permalink)
SouthCoastPhil's Avatar
9 pp for me today.
88 Venetian Blue Coupe "B"--gone, but not forgotten
93 964 C2 Coupe "BNC" ("PNC" on some days!)--PSS9s, Big Reds, Strut Brace, Recaro SRDs, Schroth 5-pts, DAS bar
Old 11-18-2013, 08:07 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #177 (permalink)
Porsche-pa
75Carrera's Avatar
Thank you Bill
Thank you Bill! Just bought another car to play with over the winter in the garage. 95 993 cab. This is a wealth of information about the models and the comparisons are eye opening for sure. When are you gonna write a book? Only a few of you guys left with the history and passion for the air cooled years.
Merry Christmas from me and my faithful '75 ;D
Donny
Current Garage:'04 996TT S Cabriolet, 1975 911 Carrera 3.2 powered (my Precious),
Also rans...
'02 996TT, '03 996TT, 1967 912, 95 993 C2 Cabriolet, 76 911S Carrera, 2014 Carrera S, 2014 Turbo S, 1999 AMG SL, 1966 Lotus 7,
Donny
Old 12-16-2013, 03:10 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #178 (permalink)
994 vs 993
Bill:
Your knowledge is just outstanding. I am a mechanical engineer and own a 1992 C4 964 cab. I like to get my hands on as much information as possible on these cars. You should put it in order and publish it some day. There are a lot of guys like me who would like to see it. Keep up the good work!
Old 02-13-2014, 11:32 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #179 (permalink)
simonozrs's Avatar
Bill
Just want to thank you for the effort you put in to pull this thread together. Its an invaluable resources to those of us with 964 and 993's.
Ive got a 1996 Carrera RS Club Sport stashed away. If theres any way I can help you with photographs or information relevant to the M003 optioned 993 RS cars, it would be a privilege to help.
Regards
Simon
2012 Porsche Cayenne S V8
1974 Porsche 911 IROC Tarmac Rally
1978 Porsche 911 Gravel Rally
1978 Porsche RSR Speciale under construction
Old 07-12-2014, 03:27 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #180 (permalink)
