Fly wheel speed reference sensor????
Hey guys i am replacing my speed reference sensor for the flywheel , I cant get the sensor out of that little bracket that attaches it to the transmission. Is it even supposed to come out of the bracket, i have beat it, pried it with a screwdriver soaked it in PB blaster all night but IT WILL NOT COME OUT. Isnt it supposed to just have one screw that holds it in the bracket or what???
![]() ![]() Thanks JERRY
1992 968 2011 Cayenne 2007 997 Turbo 1991 964 Turbo 2005 955 Cayenne |
AFIK, it's just the one bolt. I'd hold the bracket in a vise (padded), then use some big vice grips on the sensor body to twist it.
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
Thanks Don will try it.
JERRY
Manassas, VA
Flywheel...
Jerry,
You got your engine out? How was it? What are you replacing? I will be trying this too, someday. Thanks, Mark
1991 964 Polar Silver Metallic Turbo Coupe |
Hey Mark, yes i took my engine out, ive replaced most of the stuff around the engine, cleaned everything the best i could. I just replaced the engine sound/heat shield today. A few more minor things then its going back in. Ill post pics and the procedure to remove a 965 engine maybe tomorrow.
![]() ![]() JERRY
