Front air ducts for 964
Hi I am looking for places that sell sir ducts for brake cooling. I havenīt found any online shop that has them in stock.
André Magnusson
Old 05-22-2008, 01:45 PM
Tom W's Avatar
While everyone wants to cool their brakes, there are no good kits for the 964. In almost all cases it's not really necessary either.
Tom
SL63 AMG Daily Driver
'92 964 now a GT3R/GTL toy for track fun (Tom's Turtle)
Old 05-22-2008, 03:34 PM
Metal Guru
911nut's Avatar
Tom, some people just want the ducts for "looks".
Andre, did you try Getty Design?
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 05-22-2008, 04:10 PM
Max Sluiter
Flieger's Avatar
Dave Bouzaglou at TRE has the brake air deflectors that fit onto the A-arm.
tremotorsports.com
Old 05-22-2008, 04:13 PM
rsrmike's Avatar
If your lucky you local body shop has several plastic bumper covers they would love to get rid of...
I took an old Boxster front bumper cover and cut a section out of each corner. The curve matched the factory arms/deflectors perfectly.
It increased the surface are and also extended it much lower to the point they were nearly touching the ground under braking.
Seemed to help his car...It took about an hour and the most expensive parts were the 6mm bolts and fender washers holding them to the existing defleftors. Good luck
Old 05-27-2008, 04:19 PM
We were having brake fade on the track last year. We put in fresh ATE super brake fluid, and we swap out the stock pads for Pagid yellow RS29's before each track event. Now we can run in back to back sessions with no fade problems. The Pagid's aren't cheap, but neither is missing a turn.
Cheers,
1992 911 C2
1966 E-Type OTS
Old 05-29-2008, 09:35 AM
I am taking out my fog lights on a 1991 c4, I wanīt the holes and will tru to get air to the oil cooler, ac or brakes, I donīt know exactly jet.
Old 06-10-2008, 05:44 PM
Bill Verburg's Avatar
I've found that the ducts don't help brake cooling much, the A arm diverters work well for that, you can even double them up for improved performance
The front intakes can let a little more air into the coolers/condenser.
Most of the usual suspects, BW, BB, MAS, et al can help you out
Bill Verburg
Old 06-11-2008, 04:32 AM
Sorry I just moved here from sweden living in nc, Raleigh. what is BW, BB, Mas ? are they internet stores?
Old 06-12-2008, 05:06 PM
here are some oem's
Better bodies
MA Shaw
BW Motorsports
Bill Verburg
Old 06-12-2008, 05:35 PM
Chakka71's Avatar
Brake Cooling
I've been reading about different options and want to move forward with some cooling assistance. Previous weekend had me doing back-to-back sessions and I had a little smoke coming from the front when I came in.
I'm running Endless fluid, Pagid pads, slotted zimmermans and 18" wheels on my RSA.
From what i'm reading, it seems the extending the deflector is probably the cheapest and is more effective than fog light replacement inlets w/hoses.
Has anyone measured the actual temp before/after trying these different cooling methods?
PCA National Instructor
93 RS America (some things done to it....)(gone)
85 Carrera (gone)
06 BMW M5 (gone)
"If you ain't first, your last"
Old 11-05-2010, 07:03 AM
