964RS vs. 964 RSR shocks, discuss
Hello All, What are the differences between the RS and RSR Bilstein shocks? Is it just valving?
I'm looking at getting a set of RSR shocks and want to make sure they will work on my car too, it's a 1993 C2 narrowbody. Thanks, James
You will never know the feeling of a driver when winning a race. The helmet hides feelings that cannot be understood. Ayrton Senna 1993 964 RS |
I don't know for sure but suspect that any difference in shocks would be in the valving.
AFAIK the canister shocks weren't introduced until the 993RSR and GT2EVO models came out these are the 993RSR Bilstein cannister shocks
Bill
Would the RSR's have used 965 trailing arms instead of 964? Seems like I remember the 965's using a different shock. |
Went through this recently myself. The valving is different but the RSR shocks also have larger diameter shafts. Lots of info on the interwebs but here's the bilstein specs:
Model Application Body (Steel) Valving Rebound/Compression Part Number PORSCHE RSR Insert S Cartridge Only 1610/1600 F4-RE3-5049-H0 Strut L S Threaded Body 1610/1600 K4-V36-58774H0 Strut R S Threaded Body 1610/1600 K4-V36-58773H0 Rear S Threaded Body 1800/1700 K4-BE5-59545H0 PORSCHE 964 RS 89-92 Strut L S Threaded Body 2590/840 F4-V36-0155-H0 89-92 Strut R S Threaded Body 2590/840 F4-V36-0156-H0 89-92 Rear S Threaded Body 415/237 F4-B46-1487-H0 |
OK, thanks for al the help. I guess only one question remains and that is if the rears are indeed different. I will call Bilstein tomorrow and see.
Cheers, James
I don't know for sure but suspect that the answer is yes. I do know that lots of guys that raced 965 and probably the 3.8RS too changed to the n/b arms so that they could use wider wheels
Bill I'm reporting you for posting porn.....
2001GT3Cup/93RSA/944Spec#19 |
Are there different strut mounts? I believe the 964 and 964 Turbo have two different mounts, don't they?
there was a change in the street mounts for MY90 up
I have to look again. I bought turbo shocks and springs for my 964 and the top portion of the shock was much different on the turbo version, shorter I think. I assumed I needed a new top mount. Are you saying I should have inverted the mount?
#1 is the n/b position #2 is the w/b position. ![]() Cupcar posted the following info, in this thread RS & Cup used monoball mounts RS on left Cup on right ![]() RS bilstein ![]() Cup bilstein, note larger rod
OK, I have confirmed that the RSR shocks will work on a narrowbody car. Now, what spring rates are folks running on these? This car will be eventually used for Club Racing but for right now I do need to drive it to the track although comfort is not important. Lastly, what size are the springs and who should I get them from Eibach?
Cheers, James
I know guys that run these rates on their dual use rides, but they have the advantage of adjustable shocks, Moton & JIC. It's very doable when the shocks are adjusted down a few notches
if you decide want to run 550# springs in the front, i have a pair of brand new in box eibachs for you.
fyi, take a look at the rear monoball mounts that bolt to the trailing arm. chances are they will be narrower and with a larger i.d. than stock. i had a cone/sleeve setup machined by jerry woods and all works well. good luck with the set-up! |
FourDigits, Sent you a pm on the springs.
James
pm returned....
I put the eibach euro springs on my turbo but since they are shorter they have torn up my bump rubbers. Is there a different shock for this setup? They dropped my ride height about an inch, handling is MUCH better. I can't remember the rates but I think they are a bit stiffer than the rs.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
i have a 1991 turbo.
looking to install 964RSR shocks. Is this a direct bolt on? I assume it will allow me to get lower? Last edited by tcsracing1; 10-09-2015 at 08:48 PM.. |
Bilstein Part numbers:
