Phase 7
Well I've started the ball rolling on Phase 7, which will be to update the rear suspension to RS spec
for reference here is Phase 1 last year in phase 6 I did the front Rs uprights and second GT2 oil cooler Phase 6 parts ordered so far 993.331.045.80 Kinematic Control Arm x2 RS, top rear 900.067.323.09 M12x1.5x90 hex head bolt x2 K/T inner 993.331.219.01 eccentric washer x2 K/T inner 999.507.384.09 M12x1.5 nut x2 K/T inner 999.084.449.09 VM12x1.5 nut x2 K/T outer 993.331.041.81 A arm /L x1 993.331.042.81 A arm /R x1 900.378.052.09 M12x1.5x80 hex head bolt x2 a/a trailing 999.084.445.09 VM12x1.5 nut x2 a/a trailing 900.378.051.09 M14x1.5x100 bolt x2 a/a leading 900.380.012.09 VM14x1.5 nut x2 a/a leading 900.380.009.09 VM12x1.5 nut x2 a/a ball joint nut 993.331.047.03 Camber control arm 96- x2 not RS specific, top forward 993.331.217.80 Eccentric screw x2 c/l, top forward inner 993.331.219.80 Eccentric washer x2 c/l, top forward inner 999.084.445.09 VM12x1.5 nut x2 c/l, top forward, inner 999.084.449.09 VM12x1.5 nut x2 c/l top forward outer the difference between the early 993 supension, later 993 suspension and RS is in the stiffness of the bushings, mine will be set up for min kinetic-toe intrusion The stiffest bushes are used on the RS and can be identified by the green dot, same as used when identifing the RS sway bar bushes ![]()
Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes | Last edited by Bill Verburg; 12-04-2008 at 04:46 PM.. |
Green (dot) with envy again!
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
Says the guy w/ full ERP rear suspension
Yeah, the world's most expensive turnbuckles.
I like where you are going with your approach. Starting to work on my winter punch list as well, but not nearly as in-depth.
Manassas, VA
Bill,
Are you, or have you removed the rear wiring harness for the ABS and pad wear sensors? If so, I could use two of the rubber grommets that secure the harness to the chassis as shown below. I cannot find a Porsche P/N in the PET. Thanks, Mark
1991 964 Polar Silver Metallic Turbo Coupe |
Mine is a 993 and i'm keeping all of those parts
Manassas, VA
Bill,
I take it from your answer that the 993 uses the same grommet on the wiring harness. Any thoughts on how to obtain a P/N for the grommet? Is it worth a trip to the dealer with the picture above? Is a Porsche graveyard my only hope? Thanks, Mark
Mark I just looked all over the 964 PET and did not see that grommet listed. That does not mean it is not a part, but it could be part of the harness assy.
Look up 964.612.185 - I don't see a picture of it, but this is the rear brake harness, I bet the grommet is part of that...
Grommet is part of the harness...I picked up a used set from a 944, cut them off and added them to my lines...
Manassas, VA
Don,
Thanks. (Sorry for the thread hijack) I searched PP for 964-612-185-00 and did see a listing for a "Brake wear harness" for $311.50. I'll keep my eyes open for a used, burnt, or broken one to get a pair of those grommets. Since Turbo3.6 found some on a 944, it seems they are common to several models. Thanks, Mark
This is the target area
Here it is $2000 worth of 993RS rear suspension
let the games begin.. ![]() ![]() I cannot believe how light these things are
Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes | Last edited by Bill Verburg; 12-03-2008 at 04:05 PM.. |
Aside from the harder bushings, is there any difference?
Sweet!
A friend did this job last year, he couldn't find any geometric difference. As I proceed I'll certainly be looking to see differences but as the fellow that did it already is an extremely meticulus sort, I don't expect to find anything.
Some more pics of the arms before installation
None that I can see, but putting them side by side will be the telling test.
The weathers been brutal here, so no progress
What a long miserable winter
![]() More parts solid rear suspension inner mounts ![]() ![]() Upgraded front monoballs & camber plates ![]()
Started the dis-assembly
step 1 drop the rear suspension to replace the side-mounts, 4 bolts( and a few smaller ancillaries and shes down ![]() ![]() The bushes on my rubber mounts were corroded to the al. sidemounts some effort was needed to pop them out., The new ones slide in easily ![]()
