Oleg Perelet
RS engine mounts Kit content and part #'s ![]() Besides mounts everything else - just fasteners, I'm sure one can find bolts and nuts at near by store: ![]() ![]() ![]() ![]() All together: ![]() New and old:
Science is NOT optional
$79 for everything?
I tell you what, I don't miss my old saggy baggy stock motor mounts. I went Wevo a long time ago. Installing them was about my speed for wrenching too. Did you reinforce/weld your cross bar already?
PCA member since 1993 |
Oleg Perelet
Rob, that bill is for supplemental bolts & nuts - as I said you probably can source them else where.
Mounts p/n 964-375-043-81 they are about $170 per piece. Oleg. |
Oleg Perelet
964 cam horror - Rennlist Discussion Forums I do not have problems letting experts to look at mine. Oleg. |
I've seen this type of camshaft spalling/pitting in several different engines and have been told by engine design engineers that this is typical failure of the hardened surfaces. I tore a 2004 Jeep engine apart that had this pattern on several lobes but had a couple that were almost completely flat and totally worn through the hardened material on both the cam and the followers. Two lifters had worn so much they had holes in the bottom. There was no sign of scuffing on that cam either. Once the hardened material was completely gone, everything looked nice and smooth - almost polished.
1990 964 Coupe 1986 Carrera 3.2 Targa |
Oleg Perelet
Aluminum lower valve covers Factory aluminum valve covers - 964-105-116-02. ![]() At time of writing there's person on ebay selling brand new sets. Look to me as factory castings: ![]() ![]()
From what I have been able to figure out the magnesium valve covers were used up until 1990 or mid year 91 and they switched over to aluminum at some point in 1991. My 90 C4 had magnesium covers and my 93 has aluminum. Most of the 964's I have seen have aluminum but they are mostly 92 and newer. It would appear they are factory and used the same tooling as the magnesium parts. The shrinkage of aluminum and magnesium are nearly identical. Although the finish grinding on the aluminum is not the best. Look at the openings for the spark plugs on the aluminum pieces there is far too much flashing for my taste.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS, Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others Last edited by Cobalt; 06-17-2015 at 03:59 AM.. |
Oleg Perelet
Temperatures Here are some Temperature measurements of well warmed up engine: before cat: cat: muffler: muffler2: oil tank: oil filter: |
I absolutely love this stuff. Great thread.
I have the stones to jump into something like this but I wish I had the knowledge. I believe there's a lot of little details (although I may be wrong) that a rookie isn't seeing here. The "stuff" that separates a so-so 911 guy from a really good 911 wrencher, never mind the DIY-er home "I'm no mechanic" guy like myself. I don't even have a 964 ..... yet.... but I'm currently working on that. Maybe by the end of Sept there could be one at my house. The one I'm looking at needs the motor pulled for sure in the next few years. I wish I had a "guy" like "Perelet" as my neighbour to help guide me. I want to do it all myself but having those eyes that actually know what to do for the first go around for me would be god sent.
Tom From the Land of the Great White North ......never be afraid to try something. Remember, amateurs built the Ark, professionals built the Titanic |
Hello Oleg, very nice. I hope it has turned out well for you. I'm sure it has.
Sorry to ask but: 1.I see the photos where you were considering a sealing ring at the cylinders, please confirm what you used. Is it the late 964 rings machined in? 2.How do you like the LWFW set up? Was there rust on your input shaft? Apparently the correct grease is important or there is trouble with rust compromising clutch release down the road and some clutch replacements have missed this. Please advise regarding appropriate greasing considerations to avoid this. Best Regards, Carl
PCA member since 1993 Last edited by rbogh901; 10-04-2015 at 08:39 PM.. |
Oleg Perelet
Machining opening for 993/964 ring in the head is IMHO very bad idea (see my post I measured ring). I've heard some shops do that. 1st there's almost not enough clearance to fit ring - it will end up jammed between head and cyl. 2nd and no less important when time comes to replace cyls/pistons you'll need to get 6 cyl heads at top of that. New cyls/pistons require surfacing of the head and your head will have deep groove for ring right there ![]() If you go back I summarized it here: post8657740 I do not day-drive car. LFW feels more harsh compared to DMF. But them DMF had springs and all gears. DMF is actually piece of art mechanically, here's good reading: http://www.understeer.com/pdf/dualmass.pdf I live in rural hilly area, my private road goes up hill about 20deg up from garage and the about same down - I have no problem stalling etc. 1st I thought about reprogramming my chip (I did that awhile ago for bmw's) but never got around. Quote:
Oleg. |
Good enough then. Thanks. Reviewing your post makes it clear now.
PCA member since 1993 Last edited by rbogh901; 12-05-2015 at 09:37 PM.. |
Oleg Perelet
From emails, here are some illustrations on cam timing described here:
post8656019 process is described in factory manual. It is way easier to do both cams at same time. Otherwise you'll have to switch cylinder banks several times. ![]() I used 2 Z blocks, 2 tensioners (autozone brake tool - see posts above): ![]() Dial gauge needs to to be on valve spring seat: ![]() I had to buy dial gauge extensions to extend shaft to reach spring seat from here - 22 Pc Indicator Point Sets - Dial Indicators - Measuring - Products
Perelet, is your engine back together yet and running? would like to know how leaky it is or isn't now?
Wonderful... Now to buy a 964!
Wonderful, Oleg! Please keep it up. Do you do this work for others or is this just a hobby of yours. What was your background? Were you a Porsche mechanic in Europe or here in the USA? Thank you in advance for any answers.
John |
He's a wizard, and generous with his project documentations, unfortunately he hasn't been on for a while.
Oleg Perelet
![]() Quote:
https://www.linkedin.com/in/olegperelet But most of people know me because my weekend hobbies fixing cars I was doing this for few decades.Quote:
![]() Sent from my iPad |
not sure if its a technical issue on my side...but i can't see the pic's anymore? links broken?
