Bubbling well's Avatar
Sway Bar Drop Link
Hi guys,
On my '91 C2 Targa, I am changing out the old suspension to Bilstein HD and H&R springs and have just finished the rear. Now I am moving on to the front and realized the drop link boots are torn. Here is my question. Since the ride height will go lower, should I go to RS or M03 spec links? Or should I just stay stock for the existing stock sway bar? Also noticed there is a Tarett brand in the market. Does anybody have an experience in using it?
Thanks in advance for your input!
BW
Old 09-17-2012, 05:39 PM
I think the links Tarett sells are Rennline.
Old 09-18-2012, 05:53 AM
Max Sluiter
Flieger's Avatar
Tarett makes their own antiroll bars so I would think they make Rennline's drop links if anything.
Old 09-21-2012, 07:08 PM
You're correct. The monoball top mounts they sell are the Rennline pieces.
Old 09-21-2012, 07:18 PM
rs27carrera's Avatar
I believe stock will do as well, but they are pricey to buy so RS could be a solution if going for new.
I had same trouble, boots were gone, but I found that joint was havin no paly at all. I bought another car pall link and took boots from there, worked perfect and cost just pennies.
Kind regards, Harri
964 C4 1992, 930 "RS3.0 looker", Carrera 3.0 1976
911 2.4E 1972 (to be 2.4S+ spec race car), 911 2.2T 1967
Old 09-22-2012, 01:40 AM
If you're going to run at RS (or lower) ride height, then I'd suggest the RS drop links.
93 RS America
Old 09-26-2012, 08:58 AM
