Removing headlight switch - 993
Hello, just discovered this forum. I've got a 993 C4S and its my pride and joy.
The light switch has been a bit erratic recently. The headlights are OK, but when switched on, the dashboard lights go off and on intermittently when going over bumps. Loose connection? How do you get the switch off the dash board for repair (sand all of the connectors) or replacement?
Thanks in advance.
Old 01-07-2013, 07:32 AM
Same problem and would love to see some simple instructinons
Old 06-10-2017, 05:47 PM
Same question, but for 964.
Ralph W
Instagram @ ralphwlll
1990 C2 Cab
2006 Nissan Frontier
1986 F250
Old 06-11-2017, 09:45 AM
drb930's Avatar
The switch knob and switch holding collar come off from the front of the dash.
You then need to remove the switch from the rear of the lower dash.
To get your hand up there you will 1st need to remove the warning control unit which is held in with 2-10mm plastic nuts.
It comes out a lot easier than it looks with a good 1/4" drive metric sockets with the wobbly adapter extensions.
Loosen the box, pull it down to the area where you can get at the plugs and disconnect the 2 plugs.
The plugs have like a ratchet arm that disconnects them and remove the box.
You will now be able to get your hand up to where the headlight switch lives.
If you are on the larger size of body and or hands, you will have to remove the drivers seat 1st before any of this work.
Thanks,
Dave
3 Things To Live By - You can't be Too Rich, Too Thin, or have Too Much Horsepower!
Old 06-14-2017, 09:33 PM
Any details on how to remove the knob and is the 964 the same. Does it just pull off or is it attached some other way? Most of the information I have found is for earlier or later cars. I have a new switch on the way maybe able to figure it out once I have is in hand. I have looked here and Rennlist and have not found any clear instructions. Thanks for the replies.
Ralph W
1990 C2 Cab
1986 F250
Old 06-15-2017, 09:14 AM
drb930's Avatar
Know just pulls straight off.
964 & 993.r the same.
Old 06-15-2017, 09:35 AM
Thanks for the reply, didn't want to break it during disassembly, new switch should be here today.
Ralph W
1990 C2 Cab
1986 F250
Old 06-15-2017, 09:52 AM
Raleigh993's Avatar
Try some Deoxit Contact cleaner & lubricant (or any contact cleaner)
https://www.amazon.com/Hosa-D5S-6-DeoxIT-Contact-Cleaner/dp/B00006LVEU/ref=sr_1_9?ie=UTF8&qid=1497559285&sr=8-9&keywords=crc+electronic+cleaner
It worked on my headlight switch and did wonders for a balky ignition switch.
Old 06-15-2017, 01:43 PM
You were right about the warning control unit although I used a couple of 9mm sockets and the outboard nut was a pain. Managed to get under there with out removing the seat but it was tight. Replaced the switch and rear spoiler dam.
Thanks again!!
Ralph W
1990 C2 Cab
1986 F250
Old 06-16-2017, 12:40 AM
