964 clutch/flywheel upgrade question
hi pelican-land! does anybody know if a 997 gt3 rs flywheel is a direct replacement for a 964 flywheel, or know of any other factory upgrades? i have seen some 996 cup clutches with 964 part numbers, etc so was wondering if anybody knows the run-down on what clutches and flywheels can be used with no or little conversion. please let me know, and thanks in advance!
Old 01-23-2013, 04:49 PM
redturbo911's Avatar
I believe 964 and 993 are inter changeable.
Tony
91 964 c2 black/ Work in progress/Finally back on the road
85 EURO 930 Black slightly moded slowly reviving her
77 911tt EFI wide body red/ Slightly modified SOLD
Old 01-23-2013, 09:45 PM
Bill Verburg's Avatar
There are some small difference but as long as you use 997gt3RS single mass flywheel/clutch and pp it should all work, If you try to mix and match probably not
Bill Verburg
Old 01-24-2013, 07:52 AM
If you do a LWF, you can probably use the standard PP, but it does take a different sprung hub disc otherwise it will rattle cruising down the road however the disc is twice the money, a different guide tube, different TOB, and pilot bearing. The sprung hub will only rattle under hard loads at slow speeds with the LWF.
Technically it should the the matching LW PP, but that is $1200 vs about $340. When all said and done it ends up being about as much as a DMF clutch with flywheel replacement if you dont do the LW PP.
The sort answer is no, you do it all one way or the other, and you absolutely have to change over most of the componets to the other style. The stuff doesn't physically fit otherwise. If you are going to do it there should be a reason and the reason is obvious so there shouldn't be any reason to cheap out and not do the LW PP. Then it is about $900 more than the DMW Flywheel and clutch kit. It will be a few hundred more every time you do a clutch thereafter as well.
Old 01-24-2013, 04:54 PM
thanks for the info guys! i'm about to have my first motor rebuilt, and there are a lot of "while you're in there" options to weigh out in the meantime. the info really helps, and we'll keep you posted when it all comes back together!
Old 02-19-2013, 05:50 PM
