Will I need brake flex line adapters for brake upgrade?
I'm in the process of gathering up my brake components for a big brake upgrade for my 964. Front calipers will be Big Reds 993tt front calipers with 993 rear calipers. Currently I have stainless steel braided Goodridge flex lines hooked up to my stock frt/rear 964 calipers. Will I need to buy new brake lines for this upgrade or will my existing lines simply hook up? Are their adapters I can use??
Many thanks in advance,
Dan
Old 02-21-2014, 06:23 AM
swftiii's Avatar
Nope. If what you have fits the 964 calipers, then it will fit the big red/black and 993 rears as is. I did the big blacks and 993 rears and had no issues. Just remove the 964 calipers and install the new ones.
Old 02-22-2014, 04:00 PM
swftiii, very much appreciate your reply. Sounds good, one less thing to think about. Should be a straight up install....
Dan
Old 02-23-2014, 10:51 AM
swftiii's Avatar
As long as you have the adapters for the front to fit the 964 mounting points, yes.
Old 02-23-2014, 01:11 PM
