Go Back   Pelican Parts Forums > Porsche Forums > Porsche 996/997/991 Forum
Brian Minson's Avatar
Fix the case and rebuild OR scrap the idea?
I tore down my M96 engine during this shutdown and found out the issue with the engine was a rod bolt that let go and sent the piston into the sleeve of the case. Or this was a classic D-chunk that went a little bit beyond normal.
Is this case toast or can it be repaired (within reason) or should I just scrap the idea of being able to rebuild the engine?
Thanks guys,
Brian
Video of the damage to the engine: https://youtu.be/h_2dEuj5efI
Old 04-30-2020, 07:38 AM
JFP in PA's Avatar
Thanks guys,
Brian
Depends upon your tolerance to financial distress.
This engines are eminently repairable in the hands of the right machine shop. We have seen customer engines where parts from one cylinder ended up two cylinders over, and the engine is back on the road with a full set of Nickies, new rods, and aftermarket pistons; and is probably way more durable than when it left the factory.
On the down side, it took some time (the process of just getting the Nickies installed took almost two months due to backlog), and was anything but cheap.
Accrochez-vous bien de vos rêves..........."
Old 04-30-2020, 08:59 AM
914turboford's Avatar
LS1 baby!
1974 Super Beetle. Turbo Twist 18" wheels. 928 front spindles and Brembos. 944 Aluminum Trailing Arms. 230hp Acura longitudinal V6. Work in Progress
Near Tahoe
Old 05-14-2020, 04:43 PM
there is always that Porsche factory short block...
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 05-15-2020, 07:20 AM
JFP in PA's Avatar
Porsche no longer offers many M96 engines, either as short blocks or complete; selling only bear cases at nearly $8K per. You can re sleeve the case with Nickies for less than that...............
Old 05-15-2020, 08:26 AM
