Go Back   Pelican Parts Forums > Porsche Forums > Porsche Autocross and Track Racing
Send a message via AIM to cardsrule
2 options, need help
I thought I knew what I wanted to do with the interior in my 930. I am going to do a bunch of DE's and AX's this summer. I am not going to ever do any wheel to wheel racing (I say that now ).
From my other post on this forum, "harness question" I decided to go with a roll bar, sparco evo 2 seats, and a six point harness. Well after talking to a few people I begin thinking that I might not need all of this. What if I just put in a non-race adjustable seat and used the stock belts or used a 4 point harness? I am planning on doing some long drives this summer and I am scared that if I get race seats I might kill my back.
What would you do?
Thanks in advance,
Scott
Current: 02 996 C2 6-speed
84 911 roadster race car
on track by 11-11
Past:79 930 EFI
Old 02-14-2006, 11:00 AM
GFCC
Jeff's Avatar
Just keep your stock seat(s) and put it (them) in for long drives. All the mentioned upgrades are for safety and just because it is not wheel to wheel safety should still come first.
Jeff
1976 911 Coupe w/ Euro 3.0 - Sold
1987 Carrera Coupe - Sold
1999 Carrera Cabriolet - Current
Old 02-14-2006, 11:13 AM
GFCC
Jeff's Avatar
What does your screen name stand for?
Jeff
Old 02-14-2006, 11:14 AM
IROC's Avatar
I've done some long drives in Sparco Evo 2s and they're not that bad. In fact, I kinda like it. I drove from north Alabama to Daytona (Rennsport) and aside from a need for some additional lumbar support, they're great.
Getting in and out is the biggest drawback to using these seats on a daily basis (which I do). Once you're in them, they're really quite nice.
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 02-14-2006, 11:19 AM
bigrubberjeep's Avatar
Have you done any DE or AX's yet? If you havent I ASSURE you that a race seat will become your #1 wish after you feel your forearms soreness from clinching on to your steering wheel in order to keep your body from ****ing to the passenger seat under a hard turns.
Safety is #1, and if you ask around here, most people will tell you that race seats can actually be very comfortable if mounted correctly, not to mention, you need to give the seats a good butt test, sit in it for 15 minute or lenger if they let you, don't just buy en EVO2 because of the name or because many people have it, even though it may be a great seat, it may not fit you as well as others.
Finally, if your going to get a harness, I doubt the difference from 6 point to 4 point will make much diference, except when your life depends on it.
85 911 SuperSport
No more looking! The jewel is mine!
89 Jeep Wrangler
A jewel in the rough
2000 Grand Cherokee
Family Wagon with Jewels on board
Old 02-14-2006, 11:25 AM
nostatic's Avatar
A local guy in an Evo had a 4 pt harness, Momo wheel (no airbag), and slammed into a corner worker bunker after trying to avoid debris on track. Last I heard his face was smashed and he was in a drug induced coma. I don't think he ever came out of it. 4 pt...just say no.
I think you either go with stock seat and 3pt belts, or get a proper seat and go with 5/6pt harness and a roll bar. As for long drives...what do you consider long? This weekend I was at close to 1000 miles between the drive to/from LA-Las Vegas and laps at LVMS (and yes, about 250 miles of that was *on track* ). And with traffic it wsa 6 hours straight on the trip there. I've also driven from LA to NorCal for track events.
Then again, I think I might be just a tad hardcore...
Old 02-14-2006, 11:26 AM
Wow, thanks for the quick responses. sounds like the bar and the race seats and 6 point harness are the way to go.
The reason I like the evo 2's is that they are larger than most seats. I would like to get a set of evo 3's but after a post I wrote on the tech page two evo 3 will not fit in a 911 (sucks). Do you guys know any other seats made for larger guys (I'm 6'5 250 pounds)
Jeff, I just moved from Arizona to Chicago and I am a huge AZ cardinals fan (yeah I know there are like 7 of us)
on track by 11-11
Past:79 930 EFI
Old 02-14-2006, 11:38 AM
GFCC
Jeff's Avatar
Yeah, not many AZ Cardinal fans, even out here. Just wondering, I a big Louisville Cardinal fan.
You should really look at the Momo Cup seats. They are bigger seats and you sit IN them as apposed to ON them. I sat in my friends 911 with Sparco Evos and you kind of sat up more (on top). With my Momo you sit down in so it is really supportive during heavy cornering. Just got a Momo Start in the mail today for the passenger side. I sat in it once (not mounted) and it seemed very similar to the Cup but is $120 less expensive and doesn't have the thigh padding. It seems you would have more lateral support in the leg area in the Start, but I'll have to wait until I mount it to see.
Jeff
Old 02-14-2006, 01:54 PM
Dueller's Avatar
If you're gonna do it in sequence rather than all at once, I'd suggest starting out with 5/6 pt harness and a harness bar (not roll bar ...you can pick one up used for $50-75 in used parts here). You can leave your stock seatbelts in place for daily driving. yWhen/if you go to a roll bar sell the harness bar and install the roll bar. Seats would be last as with most you need to tie the backs into the roll bar unless they meet certain FIA specs.
Old 02-14-2006, 02:09 PM
nostatic's Avatar
I think harness bars are a very bad idea. I ran one for a single event and never will again. And I don't know that I would instruct in a student's car with one (I'd use the 3pt belts).
Old 02-14-2006, 03:47 PM
Dueller's Avatar
Nostatic...interesting comment...what problem did you have with the harness bar?.
I was thinking in terms of AX's...for the purpose of holding the driver in. I would agree that they would be a potential problem in a DE's
Old 02-14-2006, 03:54 PM
Super Moderator
cstreit's Avatar
Probably the usual recommendation. A harness is designed to keep you bolt upright. In the event of a roof collapse you'll crush your spine! A 3-pt will allow you to move...
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 02-14-2006, 05:16 PM
nostatic's Avatar
What Chris said. In the event of a rollover stock belts allow your upper body (and head) to move. A proper harness locks you in place. If the roof collapses, well...let's just say it wouldn't be pretty.
Maybe Auto-X speeds are low enough that there is zero chance of a rollover. But if that's the case, I probably wouldn't be interested in doing one
Actually I'm not an auto-x fan because of the lack of actual time on course. I'd rather pay the extra money, drive to the track, and get multiple sessions under my belt. But ymmv...
Old 02-14-2006, 06:01 PM
Well I am convinced, roll bar it is. (I like my spine where its at now) Any advice on the different bars? I want a bolt in. This is what I have found so far:
Autopower: $489.99
Das: $775
Safety Devices: $829
Why is there such a big price difference between the Autopower and the others? Any other ideas/advice would be greatly appreciated.
Thanks,
Scott
on track by 11-11
Past:79 930 EFI
Old 02-15-2006, 07:35 AM
GFCC
Jeff's Avatar
I have a OG Racing roll bar. It is a bolt in so to speak. You have to weld the front plates to the door sill (very strong) and bolt the bar to them. The back sandwiches the rear inner fender between the plate and rollbar.
Mine was $579 delivered to my door.
Jeff
Old 02-15-2006, 08:37 AM
GFCC
Jeff's Avatar
Scott, You have a PM.
Jeff
Old 02-15-2006, 08:44 AM
SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
Dont forget the seat back braces on both seats!!!
1980 911SC #99 track car, 993 3.6, 50 PMO's
2019 Ford F150 da dragger
2015 MB SL400 wifey DD
2008 E93 M3 DD
2007 E60 530 wifey winter beater
Old 02-17-2006, 12:51 AM
GFCC
Jeff's Avatar
SCOTITUDE, could you post pictures of your seat back braces?
Jeff
Old 02-17-2006, 05:54 AM
SCOTITUDE's Avatar
http://www.ioportracing.com/Merchant2/merchant.mv?Screen=PROD&Product_Code=SBB15&Category_Code=IOPP
2008 E93 M3 DD
Old 02-17-2006, 05:57 AM
Cory M's Avatar
The Autopower bars are cheaper because the fit isn't as tight and they bolt to the floor rather than the sills. You can pick them up used in the classifieds here for around $300. Whatever you choose, make sure you get one with the optional diagonal bar.
Old 02-17-2006, 10:32 AM
