Go Back   Pelican Parts Forums > Porsche Forums > Porsche Autocross and Track Racing
Formerly bb80sc
Vipergrün's Avatar
Race/convex mirrors and battery cut-offs?
Hey guys, any suggestions on a good convex mirror to get for track days? I don't have a passenger side mirror and want better vision. Also, which battery disconnect do you guys recommend?
-Brad
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 03-14-2006, 03:30 PM
Administrator
Jack Olsen's Avatar
I/O Port Racing sells the mirrors for around twenty bucks. They also have a smaller one, although it's not on their website.
Old 03-14-2006, 04:59 PM
earlyapex's Avatar
http://www.allviewmirror.com/racing.htm
It fit my driving position and cage better than the Longacre mirror.
http://rennline.com/interior.php/sid/5/aid/82/auto/Porsche
They have a nice battery kit as well as a bunch of other goodies.
Eric
1978 spec 911
1998 C2S
Old 03-14-2006, 05:23 PM
Formerly bb80sc
Vipergrün's Avatar
Thanks for the replies guys
Cheers
-Brad
2015 Cayman GTS
Old 03-14-2006, 06:28 PM
Formerly bb80sc
Vipergrün's Avatar
Ok, battery cut-offs.....2-pole? 4-pole? 6-pole? Are all sanctioning bodies in agreement on which to use and where to install? Should I mount in car, out of car?
Thanks for your time!
Cheers
-Brad
2015 Cayman GTS
Old 03-14-2006, 07:51 PM
earlyapex's Avatar
Use at least a four pole. Check your GCR for mounting positions.
Eric
1978 spec 911
1998 C2S
Old 03-15-2006, 04:27 AM
Stay away from my Member
campbellcj's Avatar
I have the Longacre convex mirror and like it a lot. OMP 4-pole cutoff switch. You need one that will cut the alternator as well as the battery. Tech inspectors may require you to demonstrate it while the engine is revving, in which case a 2-pole battery only switch will typically not shut off the engine.
Chris C.
1973 914 "R" (914-6) | track toy
2009 911 Turbo 6-speed (997.1TT) | street weapon
2021 Tesla Model 3 Performance | daily driver
2001 F150 Supercrew 4x4 | hauler
Old 03-15-2006, 06:58 PM
Formerly bb80sc
Vipergrün's Avatar
Thanks guys. I got the Longacre mirror and went with a 6-pole switch. I am considering installation of the switch on the cowl just below the windshield. Or, should I install it where one of the washer sprayers is? Other suggestions on where to install??
Appreciate the replies!
-Brad
Cheers
-Brad
2015 Cayman GTS
Old 03-15-2006, 07:51 PM
I really like my giant convex I/O port mirror but it is plastic and has image distortion. Does anyone make a better glass one?
Old 03-15-2006, 08:33 PM
earlyapex's Avatar
Check out the allview mirror link that I posted above. Longacre also makes a very nice set.
Eric
1978 spec 911
1998 C2S
Old 03-15-2006, 08:39 PM
Limbo
Slider79SC's Avatar
Brad,
Install the cutoff in the trunk with a pull cable exiting between the hood and cowl. That way you don't have to mess up that pretty paint.
Big ol built Duramax
Durango R/T 19’ Current Custom project
V8 M3 08’ Built and spoiled
Old 03-17-2006, 08:59 AM
Formerly bb80sc
Vipergrün's Avatar
Originally posted by Slider79SC
Brad,
Sounds like a good idea? Any pics of this setup?
-B
Cheers
-Brad
2015 Cayman GTS
Old 03-17-2006, 09:05 AM
Tom W's Avatar
Some race organizations require the cut-off switch to be behind the strut towers. Check the rules before you install to ensure you don't have last minute issues at tech.
Mine used to be up front of the brake reserviour and that's not legal for POC. So, when we removed all the crap behind the gas tank, it got moved to a direct mount near where the widers used to be.
Tom
SL63 AMG Daily Driver
'92 964 now a GT3R/GTL toy for track fun (Tom's Turtle)
Old 03-17-2006, 09:31 AM
