Go Back   Pelican Parts Forums > Porsche Forums > Porsche Autocross and Track Racing
James Chimney
tire pressure?
I have an 85.5 na, Koni's x 4, 968 30/19 sways, 16" 7 & 8 PD, Potenza RE 11's, I noticed on my 1st AX 2 weeks avon that I had more wear on the front side walls then the rears, should I bump the pressure up a bit?
didn't notice till I got home so pressure was not taken at the runs
Old 04-22-2013, 01:53 AM
Cajundaddy's Avatar
Maybe pressure, maybe alignment issues. I check/adjust hot pressure after every session.
2021 Cayman GTS 4.0L
2020 Macan (dog hauler)
Old 04-22-2013, 07:24 AM
See if you can borrow a tire pyrometer. It will tell you a lot. (This has become my standard answer!)
Old 04-22-2013, 04:46 PM
burgermeister's Avatar
I run RE11s on track and I seem to be fastest using the stock cold pressures (29/36). They like negative camber, so dial in all you can get if you haven't. I suspect 2.0/2.5 would be best, 1.2/1.8 is as good as I can get on my car. With sufficient street use, tire wear ends up reasonably even.
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 04-23-2013, 03:45 PM
Vintage Motorsport
RichardNew's Avatar
Try this. It's one of my Vintage Motorsport magazine columns
Richard Newton
Old 04-23-2013, 04:11 PM
