Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
911buff
911buff's Avatar
Cayenne drive line shudder
While driving our ‘08 base Cayenne, it suddenly began to shudder, fairly violently. It feels like it is coming from the right rear but it is hard to pinpoint. It starts at about 20mph. However, if I take it out of gear it almost completely disappears. Nothing is visibly out of sorts and everything is tight (wheels won’t wobble, half-shafts feel normal, etc.). Has anyone had this issue before? If so, what was the cause?
'71 914 1.7 - sold, '70 914-6 - sold (I am such an idiot!), '73 914 2.0 - sold, '74 914 2.0 - sold, '74 914 2.0 - sold, '67 911 - sold (Again, I am an idiot), '91 C2 - sold
Old 06-27-2019, 09:11 AM
Information Junky
island911's Avatar
center drive shaft bearing. (actually the rubber mount around the bearing.)
Common issue.
Disclaimer: the above was 2˘ worth.
Old 06-27-2019, 09:53 AM
Information Junky
island911's Avatar
here you go... https://forums.pelicanparts.com/porsche-cayenne-macan-forum/673971-04-cayenne-drive-shaft-bearing.html
and my write up http://forums.pelicanparts.com/porsche-cayenne-macan-forum/645350-drive-shaft-bearing-issue-dont-buy.html
Old 06-27-2019, 09:57 AM
911buff
911buff's Avatar
Thank you for the advice, right on the money. The rubber is torn!
Question; the Cayenne is about 8 miles from the house, can I drive it home (carefully) or do I need to tow it?
Old 06-27-2019, 04:36 PM
Information Junky
island911's Avatar
I would drive it, shifting into neutral when possible.
Or I might get MacGeiver on it where it sits... One guy zip-tied some rubber tube sections to fill the gap - think zip-tie thru a piece of say fat-wall fuel line, then wrapped around the outer ring.
Old 06-27-2019, 11:09 PM
Information Junky
island911's Avatar
Not the one I was thinking of, but theres this..
5/8" diameter x 1" long
Old 06-27-2019, 11:16 PM
911buff
911buff's Avatar
The repair is complete using the “Jimmy” method. Nine one inch sections of 5/8” OD heater hose and a coke can to slide it on with. Took it for a ride and no vibration!!! Thanks for the advice.
A few of the leftover pieces. Used wire to secure together and to the bearing carrier
Old 06-28-2019, 06:24 PM
Mike80911's Avatar
If you replace it get the lifetime one from vertex. I replaced mine with a rebuilt driveshaft unit and it gave up in a year I then used the lifetime one and it is still in the car after almost 100K miles
89 930 Cab Black
11 Cayenne
Old 06-28-2019, 06:56 PM
Porsche 944S Club Sport
guru944's Avatar
Send a message via AIM to guru944
Oh Yes, We must all do this upgrade...I did my in December 2016. It took me almost +2.5 hrs to complete, not 1hr as advertised. Well worth it. No more noise or shuddering especially during hard acceleration.The EPS/Vertex Intermediate Shaft Support Bearing upgrade is "Peace of Mind" and Lifetime.
Love My 955S Ti with great passion.
Guru944
2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport.
1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo.
http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions.
Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful.
Old 07-11-2019, 03:49 PM
Send a message via AIM to fintstone
My 2004 CTT is well north of 100K mi and I have not replaced this item. Since I may not get a lot of notice when the time comes, I have a question (based on the posts here). Is the recommended fix here the "Porsche Cayenne Turbo Cayenne Updated Drive Shaft W/ EPS Bearing Support" that comes complete with driveshaft and support?
...or is it to install the EPS Driveshaft Repair Clamping Support Mount without removing the driveshaft? https://youtu.be/t9b271NLwSE
Pelican has a writeup on this: https://www.pelicanparts.com/techarticles/Porsche-Cayenne/29-SUSPEN-Driveshaft_Bearing_Support_and_Flex_Disc_Replaceme nt/29-SUSPEN-Driveshaft_Bearing_Support_and_Flex_Disc_Replaceme nt.htm
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 07-23-2019, 08:40 PM
Information Junky
island911's Avatar
If I had to do it over again I would use the “Jimmy” method above. Or perhaps something of my own design.
Replacing the drive shaft can be a real PITA (removal). And is costly shipping, and is throwing away quite a lot just for a new rubber bumper.
Replacing only the bearing and mount is what I did.
I don't care for the inelegance of the clamping replacement. --yes, I see the “Jimmy” method as being more elegant as it doesn't require using a hack-saw and over $400.
Old 07-24-2019, 08:19 PM
