Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
High Mileage Cayene ?
I've come across a well priced 2009 cayenne S. It has 175k miles. I'll be talking about maintance history with the seller.
If well maintained should it have more reasonable life left in it.
Or will it be a constant project to keep going?
What are the important areas to check out.
Cheers Richard
Old 01-01-2020, 06:55 PM
I've got an 06 Cayenne S that I've done all the work myself and it's running strong. All the expected issues addressed, next I'll replace the lower and upper A-arms. Car has 150K and runs very strong.
Its easier asking dumb questions than fixing dumb mistakes
1974 Porsche 911 Coupe, RSR Project
1976 Porsche 911 Targa, Black
1986 Porsche 911 Carrera, Black
2006 Porsche Cayenne S, Black
Old 02-06-2020, 03:42 PM
Porsche 944S Club Sport
guru944's Avatar
Send a message via AIM to guru944
To All:
Recommend Durametric Kit for troubleshooting.
Always use 0W-40 Synthetic, Service all Fluids every 2 yrs...
Complete Suspension Upgrade in works (190K miles). Cost ~2k in parts. Lowered H & R Sports W Bilstein B8 Struts/Shocks.... Visit my Garage for details. Later....
Guru944
2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport.
1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo.
http://www.blackbirdmotorsports.com, 944/951/968, 911 and 955/957 Performance Solutions.
Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful.
Old 02-21-2020, 01:15 PM
Agree on 0w40 mobile 1, I also always use engine flush and use restore as well plus always to use a K&N oil and air filters. Also add sea foam every 5th fill up. I just replaced upper/lower arms on the front two weeks ago. Also changed the swaybar drop links since it was apart. My engine runs strong and cool, even when towing. Next I’ll change out the tranny fluid. I also need to look at my rear defroster which stopped working, maybe a fuse. I love the car.
Old 02-21-2020, 01:40 PM
I also agree on using Mobil 1, however, not comfortable with factory recommendations for oil change intervals. I have it changed at shorter intervals. It is a 2008 Cayenne S and after 9 years of ownership I still get a lot of enjoyment out of it. I had a problem with air bag warning lights for three years. The dealership replaced the passenger seat base and wanted to install a new air bag. I took it to an independent garage and they confirmed I needed to replace the air bag. I did and nothing changed. After over three years of code chasing and clearing the dealer re-calibrated the passenger seat weight sensor and that fixed one problem. The dealer eventually replaced the dash wiring harness about a year ago and that took care of the other light. They are complicated cars and should not be serviced by any technician who is not supervised by an experienced highly trained adept problem solver. The only chronic issue that hasn't been fixed yet is the loss of the date display. It is a common issue and the cause is known, however, after a couple of years, Porsche has yet to come up with a fix. I feel that the Cayenne has the potential to be very reliable and accumulate a lot of miles, however, it also, at some premature point, has the potential of being unfixable due to the complexity and cost. The fun factor is the tipping point for me.
1963 Porsche Cabriolet
Traded Audi A8L for a simple Honda Civic, Great move!
Old 02-23-2020, 08:42 AM
stormcrow's Avatar
I own a 2006 Cayenbe S with 165,000 on it and it runs strong. Just this past weekend did some offroading in the north Georgia mountains. Did 4 creek crossings average dept around two feet. Performed really well. I have air suspension so that helped along with the 20" wheels and A/T tires.
SteveKJR
Proud Owner of a 78 911 SC Targa
"A Porsche does more then just go fast in a straight line"
Old 02-27-2020, 01:36 PM
