Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
Fan blower keeps running when car is off
Help, please? '06 Cayenne S fan blower continues to run when the (1) in the OFF position and (2) when the engine is turned-off and the key is removed... any insights?
Thanks!
Old 06-18-2021, 12:20 PM
honerboys's Avatar
are you talking about the electric engine cooling fan under the hood? - it will continue to run after car is shut off until it cools down the coolant in the radiator - there is a sensor that monitors that temperature - sounds normal - usually will only run about 1-2 minutes or so
84 928 S - SOLD
2012 Cayenne S
Old 06-19-2021, 09:02 AM
Information Junky
island911's Avatar
If you are talking about the cabin fan you will want to replace the fan-speed resistor/regulator.
https://www.pelicanparts.com/techarticles/Porsche-Cayenne/35-ELEC-HVAC_Blower_Fan_and_Regulator_Replacement/35-ELEC-HVAC_Blower_Fan_and_Regulator_Replacement.htm
Old 06-25-2021, 11:08 PM
