Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
ruf-porsche's Avatar
Can't Open door from inside or outside help
Just picked up a 2006 Cayenne and the passenger side door can't be opened from either the inside or outside. When I press the FOB to lock and unlock I can hear the actuator working but can't open the door. I tried spraying the inside with WD40 and tried using a Slim Jim in the hope that I could pop the lock or reset it so that it could open. HELP
Old 04-30-2023, 05:21 PM
My other ride is a C-130J
RNajarian's Avatar
I had a similar problem and it ended up being the rubber weather strip around rather door that must be deteriorating and became sticky. It was as if the door was glued shut.
Passenger door which didn’t see that much use.
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic
2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 04-30-2023, 11:10 PM
honerboys's Avatar
if the above turns out to not be the problem i'd think there is a issue with either the linkages for the lock or the lock actuator itself - lock actuator failures are common on these cars - not sure how to get in the door to manually open it - might start by removing as much trim as you can from inside and looking to see what the problem is - i don't think the door panel can be removed with door closed - roll window down and look through slot - anything obviously wrong? - not much help i know - good luck
84 928 S - SOLD
2012 Cayenne S
Old 05-01-2023, 08:44 AM
I have a similar problem with mine, wouldn't open from the outside. I asked my mechanic and he walked out, hit the door Handle and boom, it opened when I grabbed the lever.
Video of my issue.
https://youtube.com/shorts/0n7B-vCjS4k?feature=share
Old 05-03-2023, 07:46 AM
