Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
Garage door syncing
Having trouble syncing my garage door opener...deleted old codes first and tried repeatedly but though yellow light blinked it never worked....any thoughts or suggestions?...thanx!
Old 01-04-2015, 05:17 PM
I tried and tried, could not get it to work. I gave up. Following the thread in case someone comes up with a solution.
Old 01-04-2015, 06:25 PM
Going faster all the time
Litesonic's Avatar
On my particular garage door, I needed to push the code on the drive unit as part of the process.
It took a little patience (trying more than once), but eventually, following the manual, it worked.
Now: 1997 German-built Boxster - Black
Then: (2) 1973 914 2.0 Marathon Blue | 1986 944T Alpine White | 2004 40th AE 911(996) #898 | 1987 944 Guards Red | 1976 914 2.0 Summer Yellow | 1974 914 2.0 Light Ivory | 1986 944T Black | 2006 Cayenne Turbo S - Titanium Gray
Old 01-05-2015, 12:39 AM
I too gave up for same reasons, I think I'll try pushing drive unit control as well.
Its easier asking dumb questions than fixing dumb mistakes
1974 Porsche 911 Coupe, RSR Project
1976 Porsche 911 Targa, Black
1986 Porsche 911 Carrera, Black
2006 Porsche Cayenne S, Black
Old 01-07-2015, 08:38 AM
I will give it a try and let you know! Should be a simple process...frustrating!
Old 01-08-2015, 08:44 PM
I finally figured out how to program the door opener on my 2009 CS. It was a two step process. First, I had to teach the transmitter in the car the frequency of the door opener by simultaneously pressing the button on the remote that came with the opener and the button in the car that I wanted to program. I had to get the remote fairly close to the button I was programming to get it to recognize it. It confirmed that it learned it by changing from blinking slowly to blinking fast. These are the procedure steps in the Porsche Owner's manual.
The next step, which wasn't in the manual, was to get the door opener to recognize the car transmitter. To do this, I followed the garage door opener manual to "teach" a remote. I have a Liftmaster jackshaft opener, so I pressed the the "program" button on the side of the master controller, then pressed the button in the car I wanted programmed.
This worked with my setup; hope it helps someone else and saves them the time it took me to figure out how to do it!
Old 01-15-2015, 05:16 PM
Got it to worked following recommendation by Wbyonder, thanks...works great now. The key was the missing process steps not listed in the manual. Best Regards.
Old 01-18-2015, 12:49 PM
I bought my Cayenne last March and tried for hours to get that stupid thing to work. I finally gave up.
I saw this post a few days ago and this morning I gave it another go with the instructions above. It worked!
I installed new batteries into the remote since it didn't seem to work programming it to the button (light never flashed rapidly). Then continued with the instructions above and it finally works! So glad to have that clicker off the visor.
Thanks!
Old 01-19-2015, 10:29 AM
I'm glad it's helping. I hated having the remote on the visor when the Cayenne had a built-in that should be working.
Old 01-19-2015, 05:20 PM
I guess I'll have to try that. I couldn't get mine to work either so gave up and stuck the remote up on the visor.
Old 02-17-2015, 10:24 AM
