Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
Exclamation pulsing brakes on 09' Cayenne
Hi,
I have been experiencing pulsing brakes on my 09' Cayenne. I have an idea what it could be but wanted to ask people here their opinion before I tear into it.
A Toyota tech told my son that his pulsing on his 4runner was due to the emergency brake being suck (stuck in a position; either on or off) therefore when he applies his brake, the front brakes have to work overtime to off set the non-properly working rear brakes.
That made some sense so instead of paying Toyota for a complete re-build of the bell crank, I sprayed some rust break free stuff on it, yanked hard a few times on the cable and it pretty reliably fixed his pulsing.
Now for my car, it does the same thing I think but I wanted to ask you all here what you thought. I have never taken the brakes off or anything like that so I'm not super highly skilled and theres no way i want break my Porsche.
Is there a similar part/cable/setup like the bell crank on the 4runner? I haven't really seen much on the web about that and I don't want to just yank of any old thing on the underside.
Thanks to all!
Old 11-06-2016, 09:22 AM
Administrator
Dmitry at Pelican Parts's Avatar
Hi David - hopefully the link below will help you troubleshoot and resolve the brake issue. If you need any further assistance, post a comment just below an article and someone will get back to you with more details. Best of luck!
Porsche Cayenne Brakes Tech Articles
-Dmitry
Old 11-07-2016, 01:20 PM
Free minder
Aurel's Avatar
Generally speaking, pulsing brakes means warped rotors.
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 11-24-2016, 05:44 PM
Administrator
Yes, Aurel brings up a very good point. Definitely check the rotors.
-Dmitry
Old 11-25-2016, 01:26 PM
Mike80911's Avatar
One thing about Cayennes is that they go through brakes rotors and tires like crazy. My Cayenne begins to pulse as stated above when the rotors become warped after a while so I just replace all of the pads and rotors and it goes away until they warp again. My car is an 04 with 170K miles on it so I have been through quite a few sets over the years. One thing I discovered is that a quality set of aftermarket brakes and rotors last about the same amount of time as factory parts but cost half as much. Very easy brake job to do
89 930 Cab Black
11 Cayenne
Old 11-25-2016, 03:02 PM
OEM Brembo rotors and Pagid pads for my 09 CS around $500 vs the EXACT SAME parts but with the Porsche logo for well over $1k US.
Old 12-01-2016, 12:15 PM
Going faster all the time
Litesonic's Avatar
wish I could use the cheap ones... but I have the 380mm versions... $1000 a rotor.
Now: 1997 German-built Boxster - Black
Then: (2) 1973 914 2.0 Marathon Blue | 1986 944T Alpine White | 2004 40th AE 911(996) #898 | 1987 944 Guards Red | 1976 914 2.0 Summer Yellow | 1974 914 2.0 Light Ivory | 1986 944T Black | 2006 Cayenne Turbo S - Titanium Gray
Old 12-07-2016, 12:27 PM
Free minder
Aurel's Avatar
Ouch! $4k for the 4 wheels? Maybe worth checking first if they can be resurfaced.
Old 12-07-2016, 01:21 PM
Litesonic's Avatar
The fronts are the spendy ones... and no, no resurfacing.
There is only 2mm of usable width allowed between new and out of spec.
So one set of pads, and you are likely done.
When you add all the replacement sensors, pads, etc.... all 4 corners would be close to $3100.
On a car with an MSRP of $140K, it's in proportion... but ouch none the less.
Old 12-11-2016, 01:52 PM
