Hybrid system fault
Hi,
I have Cayenne 2012, having this DTC, P309D, Separating clutch actuator insufficient slip with open clutch (showing on the instrument as: hybrid system fault on the display) Symptom: Hybrid message shown, this happen when high speed and des-aceleration from high speed of between 60-80km/h. Replacement: I have replaced new separating clutch actuator hybrid. - performing successfully clutch bleeding. - Perform clutch adaptation. -Check clutch disk and cover. - Wiring. I still have this problem still, pls advise. |
Hi, tuysombo.
I'm having the exact problem as yours for my 2012 Hybrid, workshop used 2 weeks trying to fix it but in vain. Burnt a hole replacing parts told by workshop but still couldn't resolve it. Did you manage to resolve yours? Mind to share? Many thanks and God bless! |
