Howdy,
When going slow I notice a slight clicks nose coming from the front left suspension. I'm thinking control arm bushings as the possible culprit. Before I dive into it, has anyone replaced the control arms themselves and have any tips?
2008 Porsche Cayenne S 2004 Porsche 911 Carrera |
Just found this article here. Will be doing this. Porsche Cayenne Ball Joint Bearing and Bushing Tests (955 GTS/S/Turbo 2010-2014) | Pelican Parts DIY Maintenance Article
It'll be legen-waitforit
Clicking I would assume as a half shaft, check your boots for cuts and leaks
Bob James 06 Cayman S - Money Penny 18 Macan GTS Gone: 79 911SC, 83 944, 05 Cayenne Turbo, 10 Panamera Turbo |
I recently replaced the lower control arms. The biggest difficulty I encountered was separating the ball joint. Make sure you understand how the eccentric bolts are configured; only rotate the nut when removing.
