Go Back   Pelican Parts Forums > Porsche Forums > Porsche Engine Conversion Tech Forum
no cooling issues till the bore split..The radiator i had made had been doing well
Old 02-06-2022, 02:37 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #101 (permalink)
Yan2947's Avatar
How high did your coolant temps get?
My temps are always in an area off 180 - 210 unless it is above 85f. Normal driving is never a problem but 3000 rpm’s or higher on a 85 f day and the coolant rises to 220 or. 230 and I don’t let it get higher. I love your coolant lines setup. I still plan a large rear radiator on my 86 but with a smaller radiator up front for those hot days. Are your coolant lines off off the engine block custom or did you order online? Where?
Thx
1989 911 LS1
Old 02-06-2022, 04:38 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #102 (permalink)
The coolant headers are from Davies Craig. As for temps. On track I see 100deg c and heavy traffic on hot days about the same. On the highway driving it’s about 90. Don’t forget Ls motors do run on the hot side.
Old 02-07-2022, 03:33 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #103 (permalink)
Yan2947's Avatar
Thanks for the info. My build is on hold waiting for the body shop to finish. I will still have a rear radiator but will try to add some smaller ones up front and/or in the rear quarter vents on my slant nose. I have a shortened 930 Tranny for this new project. My 89 has a g50.01 and a LS1 with a very tall 5th gear. Still gets hot but has never overheated and only get hot when it’s 85 f or hotter…
1989 911 LS1
Old 02-07-2022, 05:21 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #104 (permalink)
Found your thread after you recommended not using the subaru transmission on my thread. Can you detail the problems you were having with it, and what kind of power you're getting out of your engine?
1977 911 Targa Project: Subaru 3.6 Swap > Find me in Engine Conversion Forum
1947 Chevrolet 1.5ton truck // 1997 Jeep Wrangler Sport // 2001 Jeep Cherokee //
2006 Yamaha FJR1300 // 1988 Yamaha Radian 600 // 1976 Honda CB360T
Old 06-29-2022, 02:00 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #105 (permalink)
... following. Just missed a great '73 chassis to do this exact project.
Old 07-02-2022, 10:24 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #106 (permalink)
First breakage was at 313hp. The output shaft snapped
next was the stub axle.
next was the diff centre
after that 5th gear cracked in half
and that second gear teeth broke.
After that i brought a g96 haha
Old 07-24-2022, 06:01 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #107 (permalink)
Did you have the LSD in that subaru unit? What kind of torque numbers? I'm only going to be in the neighborhood of 256hp/247ftlb with the stock subaru 6 cyl.
I'd spoken to you on FB messenger and watched some of your vids, but didn't see any resolution to the adapter and g96 trans. Are you making that commercially available?
Old 07-26-2022, 12:07 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #108 (permalink)
Yeah I had a Tomioka lsd, With the old motor I was making about 320hp & 611nm which i thing is about 450ft lb at the wheels. Kennedy will make any any adaptor you want. My adapter is for a ls to gm set up. So im not making any kits. Personally I don't like any engine made by subaru. if you want a flat 6 just buy a 996 carrera engine. then the trans will also bolt up
Old 01-10-2023, 06:40 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #109 (permalink)
Had some clutch issues and cable issues which are now sorted. New shifter mount made for cable shift. Routing cables in a torsion tub was the worst thing ever
Old 04-18-2023, 11:21 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #110 (permalink)
it runs.
Needs a new alpha N tune now for there ITBS. But it sounds cranky with the new engine, Cam is the sloppy stage 2
[IMG][/IMG]
Old 04-18-2023, 11:24 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #111 (permalink)
Finally moving under its own power.
Old 04-18-2023, 11:46 PM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #112 (permalink)
Ryan_Cunningham's Avatar
Badass!
"Purists are the Karens of motorsports.
IG - Iron_Dad_Moto
1972 Porsche 911 - Long Term Project. 3.6TT/G96.50
1981 Porsche 911SC - In Progress.
F/A-18C/D, F-15C, F-35B/C
Old 04-28-2023, 10:52 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #113 (permalink)
This thread has been very helpful and informative. Thank you for creating it!!
Old 05-05-2023, 07:18 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #114 (permalink)
Banned
That's when I lost interest because we're looking at about $6700 + costs for the hydraulic parts which will probably be another grand or so and many hour of research, custom fabrication,
Old 07-20-2023, 01:26 AM
  Pelican Parts Catalog | Tech Articles | Promos & Specials    Reply With Quote #115 (permalink)
