so i decided to freshen up the motor, lucky i did as the heads were ****ed, i got a set of 241s that look in great shape. all I need now is a rear hump sump. Any one got one??????
![]() ![]() almost back together I just need to adjust the hood, fit the fender flares and fuel door. ![]() ![]()
cooling system is finished and crade is all finished and off to the powder coaters.
Nice. What modifications did you have to do to get the radiator to fit up front like that?
Think factory RSR oil cooler recess just bigger
How low is your car,. Im planning on running a canton road race s13 pan that is front sump like your (i assume) GTO pan,. And that picture has me worried for ground clearance.
-1977 911s Flachbau Coupe sunroof delete. Color TBD, 400hp Ls1/930 box. Basket case rebuild in progress. Short term.money pit -1973 Toyota Celica GT. White. The long term money pit -1969 Ford Mustang Mach I. 351w/TKO600. The inheirited money pit. - |
MrRPJ I dig the cooling set up. Which Jeep radiator & type of piping are you using? Did you happen to weigh the pipe?
All up the pipe work was about 4kg I just brought straight lengths and bent them with a mates bender. |
https://www.summitracing.com/parts/grn-350222?seid=srese1&cm_mmc=pla-google-_-shopping-_-srese1-_-granatelli-motor-sports&gclid=CjwKCAjwiurXBRAnEiwAk2GFZhDU1TZqiAUuWrSnCULi q9qT8Tbm-Dpk9GgK-F7PvrSmDWwSZxTKARoCQhgQAvD_BwE basically just a small, nylon, high durometer wheel for when the cradle contacts the ground to provide a rolling surface to prevent damage
I love this build. Can you post some detail photos of your rsr cut out. I've been stuck at the cooling stage of my build for awhile. I actually tried the oem Cherokee radiator but felt it was too big. I was considering welding 2 yamaha rhino radiatoms together. Any pics will be greatly appreciated. I'd also like to know how you avoidea crimping the AL tube. Thanks
Thats the reason for the 993 kit. the 993 front bar has a lot of room behind it
Funny thing is my brother is huge Jeep guy, and he suggested a Cherokee radiator also, that's sweet that it fits, and that it's big enough to cool that beast powerplant you've got in there.
Ok after a big weekend we have made some decent progress. I got the cradle back from powder coaters*
![]() I started making my raised shifter box ![]() I got the motor stripped down, rebearing the bottom end and fitted MLS gaskets throughout. ![]() started reassembly ![]() all finished and bolted up to the Subaru trans and fitted to the cradle ![]() and its in took 25mins to install ![]() ![]() ![]() Got the GT2 front flares fitted up ![]() and all in
That's looking good there! Getting closer and closer to finishing!
I spy an ARB bull bar... is that one for a Hilux?
23 Macan GTS 97 240SX 94 Land Cruiser Too many Miata's to count. |
Looks like you're on the home stretch now!
