![]() I am looking at a 01 996 turbo with 60k miles. One owner, well cared for and never tracked. What is the value range for this model? Len
Tippy or manual? Options? Color? Mods? Tune? Up to date with maintenance? Spoiler rams? 2nd gear pop out? Radiators? Slave cylinder?
No answer is possible without that info.
"Fraud is everywhere in this hobby. Believe nothing, believe nobody, expect disappointment." Last edited by Rick Brooklyn; 07-20-2018 at 08:58 AM.. |
Color? 6 speed or tippy? Bone stock or upgrades? Twists or other wheels?
![]() Thank you. Its a 6 speed. White. Don't know about maint, but likely done if at 60k. Was there a radiator problem with these? Will road test it this week. As far as I know its bone stock. Len
Coupe will be lower to mid $40s if its maintained and needs nothing.
gearhead
No, but maybe you are thinking of the coolant fittings on the engine case. They are glued in and on tracked cars they have been known to fail. The fix is to pin or weld them, but it's nothing urgent. Most people do it as part of a clutch install.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
disband
ive heard that some track groups are requiring the lines to be addressed if you are to participate.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
![]() So when the motor is pulled for a clutch these coolant fittings are addressed as a precaution? Any idea of the extra cost? Len
gearhead
![]() Ooops, I am still thinking "Old school". What is the typical cost of a clutch AND this Coolant Line repair? Len
Len, pinning coolant lines and changing a clutch are DIY fixes for you, aren't they?
BTW, the white 996 Turbo is highly desired. The color brings a premium. Agreed on the lower-to-mid $40s value. In test driving it, decelerate in 2nd gear a couple times. The earlier 996TT trans is prone to pop-out.
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
Coolant lines aside, radiators are one thing that sometimes pukes, on the 996tt. The most common one is the clutch slave cylinder though. Some pre-03 cars report a "second gear pop out " issue, which while not extremely common is pricey to fix. If the car checks out and has good records, definitely mid 40s at least, white is a rare and very sought after color on 996tts. 01s trade at a slight bit of a discount partly due to a never fully settled debate on whether 02 and later cars had a stiffer chassis. Having said that, from memory the silver one that went for more than 70k when my car was on BaT was an 01. Edit: The Master posted right as I was writing, I would have been briefer if I had read it.
"Fraud is everywhere in this hobby. Believe nothing, believe nobody, expect disappointment." Last edited by Rick Brooklyn; 07-20-2018 at 03:17 PM.. |
