3.3 engine case cost
Good Morning,
I'm looking to purchase a 1978 3.3 Porsche engine case # 678XXXX. Whats a fair price? Your feedback is very important. Regards |
If you’re looking for one specific case number to make it numbers matching to your car, then the current market for engine cases really has no bearing on it, especially if the seller knows that. Just my two cents.
3.3 turbo case in good condition? 4-5K I'd say. To complete your numbers matching 78 turbo? Sky's the limit!
Thanks guy.
As posting stated" I'm looking to purchase the 3.3 casting. I just don't want to get ripe off. I'm sure no one here wants to overpay for anything. Last edited by david3299; 02-01-2019 at 12:01 PM.. |
I'm good with tools.
I did not think 4-5K would get it done..... I was thinking more like 9-10K
72 911 Coupe "OILDOOR" 24 INEOS Grenadier (daily) 13 991.1 Coupe 2S 3.8L (currently undergoing mods) 02 996 4S |
Is the 3.3. case something different? I thought all the 3.2/3.3 cases were the same.....unless a particular s/n was at issue...
Dennis |
Yes you are and I am following that closely !!!
Case as in just the two case halves? Or a core short block with serviceable crank, oil pump etc?
I was referring to the two case and all studs
Yup, as a matter of fact 2 Porsche race shops I have used used cases other than one from a turbo. I know in one of mine a carrera case was used ( cost under 2 grand ) and was, still is a good one and was race modified in the usual way. A race car Motor so case ### not an issue and is around 500HP. The shop said the casting strength was the same as a turbo casting. What year or model it came from I do not know but some research should get an answer if ### not an issue.
Anthony @ Voitureltd Bayside WI. Last edited by voitureltd; 02-09-2019 at 11:35 AM.. |
And then of course there are the factory blank cases. These are new replacement cases that were available over the counter from Porsche. They were sold unstamped.
RGruppe #180 So many cars.. so little time!! |
