Mighty Meatlocker Turbo
That's interesting for sure. I'm much more familiar with leakage tests done on Lycoming and Continental engines and dayyyyuuummmmnnn, the numbers are often dramatically worse on cold 'v' hot engines - so much so that the cold test is of basically zero value.
Functionista
Maybe because those are operated in a narrow range and have to compensate for extreme changes in altitude/temperature?
Stock Porsche even with all the expansion of forged pistons and thin cylinders do leak down pretty well cold if they’ve never gotten too hot.
Jeff 74 911, #3 I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible. |
I agree great numbers too bad I didn't see this earlier I would have grabbed it.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS, Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others |
