Value on ‘69 s motor
Hi I’m looking for insight on value on this 1969 s motor. My plan with it is only to use as a practice motor to disassemble and assemble to learn and prepare for the rebuild of my ‘79sc motor when the time comes. There is no known history so assume core motor.
Old 06-07-2024, 08:47 PM
gearhead
Why is the fan shroud the wrong color?
Maybe post the type number and serial number to verify?
Personally, if it’s an S, it is likely worth more as it sits than after you tear it down and put it back together. Anyone shopping for a real S engine for a restoration or hot rod is going to rebuild it again and not trust your work.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 06-08-2024, 04:04 AM
Where's the MFI?
Old 06-08-2024, 05:54 AM
6404214. I have no history so no clue on shroud color or anything else. I would use it to get a feel for taking apart and reassembling but was just curious if any value. Thanks.
Old 06-08-2024, 06:52 AM
Originally Posted by nickelplated5s View Post
Where's the MFI?
No history or anyone to ask about that, I’d like to know where the rest of the car is as well…
Old 06-08-2024, 06:53 AM
gearhead
No such number. It’s probably 610, which would be a 1970 T engine. The shroud is the right color for that. Type number should be 901/03.
$3-4k? Carbs are worth about a grand and the longblock is the balance of the value.
1974 914 Bumble Bee
2009 Outback XT
Old 06-08-2024, 12:17 PM
Matt - 6390793 but 901/10. Was a 2.0 when I got it years ago, correct? Went to a C&C this morning and had 69 parts pointed out. Some I knew, some I didn't.
Old 06-08-2024, 12:57 PM
gearhead
That’s a 69 S engine.
1974 914 Bumble Bee
2009 Outback XT
Old 06-08-2024, 02:25 PM
Thanks Matt appreciate it. Here is a pic of the number as provided to me.
Old 06-08-2024, 03:10 PM
What I was told when I got it and over the years. Just figured you might know. One of those stories when you swap cars for a weekend and I ended up with the pink slip. Back then in CA they were literally pink.
Old 06-08-2024, 05:56 PM
7.0:1 > 11.3:1 > 7.0:1
640xxxx is 914/6
Old 06-08-2024, 06:37 PM
Originally Posted by Jim2 View Post
640xxxx is 914/6
Thanks for the info, appreciate it.
Old 06-08-2024, 08:24 PM
The 9 Store
640xxxx is 914/6
Makes sense. It does have a 914-6 oil cooler.
All used parts sold as is.
Old 06-09-2024, 03:53 AM
gearhead
640xxxx is 914/6
Ah-a. I didn’t think of that.
1974 914 Bumble Bee
2009 Outback XT
Old 06-09-2024, 04:59 AM
914/6 thanks for the info. If I was able
To mate it with a chassis without a transmission.. what’s it worth now? I really wanted a Porsche motor to practice on but scenario is making this interesting.
Old 06-09-2024, 08:56 PM
More specifically yet this would be from a 1970 914-6 in USA spec and fairly early in the production run. Maybe in the first 300 cars. Even so, as a rebuildable core 4k max.
Old 06-10-2024, 02:39 AM
gearhead
Yeah, my value doesn’t change with it being a 914/6. It’s basically the same thing as a 69T.
Practice on it without much concern. Once it’s turn down, it’s the case with the serial number that might be of value to some 914/6 owner.
1974 914 Bumble Bee
2009 Outback XT
Old 06-10-2024, 04:40 AM
Zink Racer
You may want to post the number on 914world.com once you have it. There are guys looking to reunite their factory 6 cars to the original engine.
Jerry
1964 356, 1983 911 SC/Carrera Franken car, 1974 914 Bumblebee, a couple of other 914's in various states of repair
Old 06-10-2024, 05:00 AM
I went ahead and started a thread on 914world to link it.
Old 06-10-2024, 09:20 AM
Hey! Nice Rack! "Celette"
rich's Avatar
Still looking for 4371 Not many 914-6 owners really want the 2.0 in the car. More of a shelf critter to say you have it.
Early Alien Sightings
914-M28/11 5.0 Hybrid (The Alien Sharkster)
I think I smell your blood in the water
WCC 04 done by the kids
Who says Aliens only abduct people.
Old 06-10-2024, 07:03 PM
