FenderGuy's Avatar
Value of 3.0 with blown piston
1980 SC 3.0
Tensioner update
Turbo Valve covers update
Air box update with bypass
New Alt and Accum within 30 miles
clean engine
miles on engine 42k as the title says (but could be more?)
Frank
1980 SC Cab Conversion (sold)
1974 914 2.0 RIP rear ended
Looking for a 996 Silver Cab 2002-2004
Old 11-07-2006, 07:11 PM
FenderGuy's Avatar
come on someone has to throw out a value?
Frank
Old 11-09-2006, 08:42 AM
andrew15's Avatar
How 'blown' is the piston and was it the result of some other problem?
I took apart a 3.0 with a piston that went and the following was UNuseable:
- 1x head
- 5x cylinders (broken piston parts scored most other internals)
- 5x pistons (see above)
- 1x rod (bent when piston ate itself)
- Crankshaft (piston failure was traced to a oiling issue and rod bearing failed)
- Oil pump (damaged by rod)
- Oil cooler (thrown out due to the likelyhood of small metal bits getting everywhere)
In fact, I was very lucky to salvage the case and a few other small internal pieces. If I was to put a value on a 3.0 engine with a destroyed piston again, I would plan on only being able to use 5 heads, the cam towers, cams, fan/alternator and some of the front timing stuff - maybe $850-1200. As a reference point, the 3.0 package I got cost $2500 and included clean Webers and a fresh reground crank.
Regards,
Andrew M
1970 911E - track / weekend car
1970 911S - under restoration
1986 930 Slant Nose - fun car
Current used parts for sale
Old 11-09-2006, 07:34 PM
