1995 993 vs 1996 993
All things being equal, mileage,condition etc. What are the advantages of one over the other. I have notice that 1996 seem to sell quite a bit higher, of course 1997 even more. I was looking for a Cab.
Old 10-11-2007, 06:02 AM
JasonF's Avatar
Try a forum search on the Rennlist 993 board. The topic gets a lot of discussion. It basically boils down to the fact that '96's produce 12 or so addtl' HP through the varioram system. Many people can't tell the difference in pull vs. a '95. However, '95's are much easier to chip and that will negate the HP gain of the varioram.
On the other hand '96's have the OBDII system which in many cars can trigger a check engine light due to carbon buildup in the SAI ports. Doesn't affect drivability one bit but you won't pass emissions in many (most?) states if the check engine light is on. The primary solution is an $8,000 top end although some have claimed that flushing the ports works.
1995 C4/Guards Red (sold)
2005 997 Carrera / Arctic Silver (sold)
1995 C4/Polar Silver (sold)
2010 Cayman S / Atlas Grey (sold)
Old 10-11-2007, 09:24 AM
racer's Avatar
'96 was rated at 282hp... '95 at 270. IIRC, 95's had some rear suspension geometry that made making and leeping alignments difficult. Later cars were corrected. Early cars can be retrofitted. If you aren't tracking the car, you will never notice.
Past:
2000 Boxster 2.7, 1987 944, 1987 924S
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 10-11-2007, 04:22 PM
jtkkz's Avatar
varioram
95 does not have it
96-98 have varioram motors
Old 10-15-2007, 12:08 PM
kilodawg's Avatar
I have a '96 it would be great to get rid of that whole drive block nightmare....
'73 914 2.0, '74 911 Coupe, '74 911 Targa
'78 924, '84 944, '86 944 Turbo, '84 911 Coupe
'84 944 (current), '96 993 Coupe (current)
'73 911T Coupe (current)
'88 930S M505 (current)
Old 10-15-2007, 12:17 PM
Now in 993 land ...
aigel's Avatar
The varioram adds a lot of torque down low - the added horspower is not the main advantage here. It makes for nice around town driving and decent grunt at 3000 rpm. The advice of buying the newest porsche you can afford also may play into this. Another difference is the basket handle on the 95, which went away in 96. Of course, that along with all the other little differences is easily changed. I was shopping 91-98 and you just end up buying the best car you can find in your range.
George
81 SC (sold)
Old 10-23-2007, 08:57 AM
techweenie's Avatar
I owned a '95 and '97 and the horsepower difference was not apparent.
As has been stated above, the 'secondary air' problem with the '96-98 is not trivial. In addition, the '95 can be 'chipped' while the later cars require an ECU main board replacement.
techweenie | techweenie.com
Marketing Consultant (expensive!)
1969 coupe hot rod
2016 Tesla Model S dd/parts fetcher
Old 10-23-2007, 11:25 AM
Now in 993 land ...
aigel's Avatar
There are piggy back chips for the 97 at least.
George
81 SC (sold)
Old 10-23-2007, 01:02 PM
