cookie cutter rims
Will 15 x 7 cookie cutter rims fit a 1976 912e? I have the standard press metal 15 x 6. Any help appreciated.
Hugh
Old 12-28-2008, 08:46 AM
UNDER CONSTRUCTION!
carrera turbo's Avatar
the awnser to your question is yes they will fit with proper tire size. i had these on a 1976 912e and it worked just fine.
hope that helps.
ed
Sometimes the first thing that comes to mind should be the last thing that you do!
Old 12-28-2008, 06:04 PM
racer's Avatar
yes and no.. depends on tire size.. ride height and alignment (camber) can also impact fitment.. as can rolling the fender lips flat..
Past:
2000 Boxster 2.7, 1987 944, 1987 924S
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 12-29-2008, 12:24 PM
For what it`s worth.......... 6" cookie cutters fit nicely on a stock ride height SWB `68 912 with 195/65/15s. NO clearance issues.
Old 12-29-2008, 12:56 PM
deathpunk dan's Avatar
Also FWIW 15x6 cookies with 205/60 rubber fit my US ride height 1971 911T just fine, as well.
Sepia brown 1971 911T.
Old 12-31-2008, 06:04 AM
