cookie cutter rims
Will 15 x 7 cookie cutter rims fit a 1976 912e? I have the standard press metal 15 x 6. Any help appreciated.
Hugh |
UNDER CONSTRUCTION!
the awnser to your question is yes they will fit with proper tire size. i had these on a 1976 912e and it worked just fine.
hope that helps. ed
Sometimes the first thing that comes to mind should be the last thing that you do! ![]() |
yes and no.. depends on tire size.. ride height and alignment (camber) can also impact fitment.. as can rolling the fender lips flat..
1970 914-6 Past: 2000 Boxster 2.7, 1987 944, 1987 924S 1978 911SC, 1976 914 2.0, 1970 914 w/2056 |
For what it`s worth.......... 6" cookie cutters fit nicely on a stock ride height SWB `68 912 with 195/65/15s. NO clearance issues.
Also FWIW 15x6 cookies with 205/60 rubber fit my US ride height 1971 911T just fine, as well.
Sepia brown 1971 911T. |
Thread Tools | |
Rate This Thread | |
