cookie cutter rims
Will 15 x 7 cookie cutter rims fit a 1976 912e? I have the standard press metal 15 x 6. Any help appreciated.
Hugh |
UNDER CONSTRUCTION!
the awnser to your question is yes they will fit with proper tire size. i had these on a 1976 912e and it worked just fine.
hope that helps. ed
Sometimes the first thing that comes to mind should be the last thing that you do!
yes and no.. depends on tire size.. ride height and alignment (camber) can also impact fitment.. as can rolling the fender lips flat..
1970 914-6 Past: 2000 Boxster 2.7, 1987 944, 1987 924S 1978 911SC, 1976 914 2.0, 1970 914 w/2056 |
For what it`s worth.......... 6" cookie cutters fit nicely on a stock ride height SWB `68 912 with 195/65/15s. NO clearance issues.
Also FWIW 15x6 cookies with 205/60 rubber fit my US ride height 1971 911T just fine, as well.
Sepia brown 1971 911T. |
