Yep, I've done that!
Car value input please!
Question for the group is I have an option to buy an 84' 930 that has some issues:
Theft recovery in the past Original engine was not recovered and 3.2 Carrera was put in. Cant tell for sure but I think a metal slope nose conversion was done after recovery. Pros: It is in good shape overall and it is a real 930 in steel. Sport seats Turbo twists What are the thoughts on the value range for this? My thoughts are to drop in a 930 engine and fix it up.
71' 911 Fully restored Tarmac Rally Long Hood RSR 03' Audi Allroad 2.7ltr Twin Turbo 350 HP Ski Machine! 00' Aprilia RSVR Mille SuperBike highly modified...Yep fun fast! 86' 944 SPEC Car 'In Process' 2013 Debut Last edited by joeblow; 01-25-2011 at 11:59 AM.. Reason: Forgot to add info... |
"O"man(are we in trouble)
Tough call w/o more information and pics. Since it doesn't have a turbo engine, I wouldn't pay anymore than a standard 3.2 Carrera, maybe less depending on the body wrok.
'84 930 is a Euro car.. ROW. Nowadays its less a concern, but *could* perhaps cause registration problems without appropriate DOT/EPA paperwork. Most cases, if its already been registered it won't be an issue, but thought it should be mentioned.
In the US, Porsche did offer the Turbo Look 911, beginning in 1984.. a 3.2 motor stuffed in place of the turbo'd motor. Full turbo body work, suspension and brakes. In essence, you have a "turbo look" knockoff Not necessarily a bad car to start off with. You could source a turbo if thats your thing.. or a 993 3.6 (with nearly 300hp, its close to the old stock 3.3L turbo anyway) Do a thorough search for rust and collision repair issues.
1970 914-6 Past: 2000 Boxster 2.7, 1987 944, 1987 924S 1978 911SC, 1976 914 2.0, 1970 914 w/2056 |
Here is the decoded VIN:
Model year: 1984 Model ID: 911 Engine Code KW HP Liter Cylinders Model 930.66 221 300 3,30 6 911 TURBO Transmission Code: 930.34 Options found on your vehicle. Option Code Description M220 Locking differential 40 % M261 Door mirror - flat - passenger's side, electrically adjustable and heatable M409 Sports seats M650 Electrical sliding roof The following codes were found, but the description may not be accurate. Option Code Possible Description I411 18-inch Carrera wheel M469 Black roofliner We were not able to find definitions for any codes below this line. I330 I391
71' 911 Fully restored Tarmac Rally Long Hood RSR 03' Audi Allroad 2.7ltr Twin Turbo 350 HP Ski Machine! 00' Aprilia RSVR Mille SuperBike highly modified...Yep fun fast! 86' 944 SPEC Car 'In Process' 2013 Debut Last edited by joeblow; 01-25-2011 at 02:59 PM.. Reason: Clean up... |
Now accepting US $ at par
Pretty sure no 18" wheel option in 1984... ;-)
Yep I wondered about that too!
71' 911 Fully restored Tarmac Rally Long Hood RSR 03' Audi Allroad 2.7ltr Twin Turbo 350 HP Ski Machine! 00' Aprilia RSVR Mille SuperBike highly modified...Yep fun fast! 86' 944 SPEC Car 'In Process' 2013 Debut |
