Should I always avoid cars rebuilt by MM
I'm a newbie diving into the wonderful world of old 911. I really want the 911S 2.7L instead of 911SC 3.0L mainly because the the chrome trims, which I think gives more vintage look (even though I've read all about the 2.7L issues). I'm looking at a car posted on eBay and the seller happens to be local. I was advised by a friend that the red fan is an indication that the motor was rebuilt by Meister Motor and should walk away. I did a quick search here on Pelican regarding MM . Shouldn't I at least give it a chance and get PPI done?
Old 03-18-2013, 11:26 PM
I would talk to the seller and see what they say. See if they volunteer info regarding whether or not the engine has been rebuilt, then you can ask about who did the rebuild job. It mostly comes down to price. At a certain price level that car becomes very attractive, even if MM rebuilt it. But I wouldn't jump to assumptions just based on the fan paint. The valve covers and heater blower motor are also painted red. Maybe the owner just got happy with the red paint...
What is the deal with the rear trunk release cable?
Kirk
Old 03-19-2013, 05:45 AM
deathpunk dan's Avatar
If the appeal is the anodized trim/brightwork...doing that to a nice later SC is a far less expensive proposition than a correctly done 2.7 rebuild.
And, keep in mind most SCs through1980 have the anodized trim you like.
2.7 + MM sounds disastrous.
Sepia brown 1971 911T.
Old 03-19-2013, 06:14 AM
vracer's Avatar
Look at it. The more you see - the more you learn.
Richard
1989 Venetian Blue Targa
Old 03-19-2013, 07:50 AM
techweenie's Avatar
I've seen a lot of painted fans, and most were not MM rebuilds.
If the engine rebuild happens to be MM, just have a mechanic thoroughly inspect the condition of the engine. The majority of MM engine rebuilds are just fine. The problem is that when their rebuilds are bad, they seem to be really bad and apparently MM does not make an effort to make things right.
techweenie | techweenie.com
Marketing Consultant (expensive!)
1969 coupe hot rod
2016 Tesla Model S dd/parts fetcher
Old 03-19-2013, 07:52 AM
For some reason the release cable was relocated...
As suspected the motor was rebuilt by MM, but the previous owner (it was passed by from current owner's father-in-law) sent it to another shop for another rebuild little over a yr later and spend a crap load of money!
Then:
Old 03-19-2013, 01:15 PM
techweenie's Avatar
Pretty sure that's part of some aftermarket security system.
It would not work as a lid release
Old 03-19-2013, 01:30 PM
vracer's Avatar
Wow! That's not a very good ad for MM, is it?
Richard
Old 03-19-2013, 08:32 PM
techweenie's Avatar
If I'm understanding what I see, the Motormeister rebuilt engine came back with the crank locked in the case and not turning. It cost $16.4K to put it right? This person was taken advantage of twice.
Lots of oddities in the Kirberg invoice. It seems a bit paranoid to magnaflux a new crankshaft, but when you're charging $16K to rebuild a 2.7 long block, I guess money is no object.
1969 coupe hot rod
Old 03-19-2013, 09:43 PM
GothingNC's Avatar
Nice how MM cut the support rib out of the engine case
John D.
82 911 SC Targa-Rosewood
2012 Golf TDI
Old 03-20-2013, 05:11 AM
kinein's Avatar
Send a message via Yahoo to kinein
Well i just bought a 993 that the top end was done by mm. Believe me i was goin to walk away from it from the get go. Just for.that reason. After talking to a few of my pcar friends about it, they all basically told me that mm didnt screw everyone.
So when i had the ppi done i told the mechanic the top end was done by mm, who himself was screwed by mm. So he understood my concern. He thoroughly inspected the engine. Compression was 180 across. And 3-5percent on the leak down. He advise me that everything chcked out and the car was good.
Believe me i used the mm thing to my advantage. The owner new he made a mistake
By having mm touch his car as many buyers walked.away just the mentioning of mm.
If the ppi checks out. You are good
1966 912 with 2.2 911 motor
1986 wide body 911
1995 993 Polar Silver
Old 03-20-2013, 05:42 AM
Halm's Avatar
Many years ago, I bought a car from a well know and highly respected forum member. It had a fresh MM rebuild. The PPI was done by an equally well known and respected wrench in Venice Beach. He told me to run away from the car and not to touch it. I wish I had followed his advice.
To this day, I stop reading an ad when I see MM is associated with the car/engine.
'17 Cayenne
Old 03-20-2013, 09:40 AM
biosurfer1's Avatar
Same thing with Victory Motorcars. They probably have a good car here or there but after all the horror threads and reviews, I dont even look at their ads anymore. Not worth the risk.
1992 968 Polar Silver
2010 Toyota Highlander SE
2006 Lexus LS430 ML
Old 03-20-2013, 10:25 AM
gearhead
I don't see a crank on that invoice. It looks to me like they reused the one from the MM build. Though for $3200 in 2005/6 I sure hope they got a set of RS Ps&Cs and that wasn't what they were charged for plain old 2.7l ones. Back then I think I was selling new kits for under $2k. The really brutal charge on that invoice is the labor. That's 50%+ more than what it would have cost to rebuild that engine back then.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 03-20-2013, 12:32 PM
techweenie's Avatar
The $3200 item is of course not readable, but ends with a "t" which crankshaft does and "pistons and cylinders" don't.
YMMV
But we can all agree that $16K for that rebuild was not kosher.
1969 coupe hot rod
Old 03-20-2013, 12:53 PM
gearhead
But piston and cylinder set does end with a t.
Old 03-20-2013, 07:47 PM
techweenie's Avatar
Ya got me there!
Old 03-20-2013, 07:55 PM
Wow...
With all the "bad press," I always wondered how MM stayed in business.
$16.5k rebuilds (for a 2.7!) every once and a while can go a long way towards keeping the doors open...
Old 03-21-2013, 06:34 AM
You can PPI it and see what happens. But for me, there are so many cars out there, I'd just look at a different one with a few less stories.
Old 03-25-2013, 10:12 AM
Fidalgo911S's Avatar
Yikes! What Tech said, somebody got taken advantage of twice.
Nate
Old 03-28-2013, 04:03 PM
