Mark N
What's the deal with high dollar Webers
These winter months has me constantly searching through the 911 used parts threads looking for parts I may or may not want for any project in the near future. One project in mind is using a set of Weber carburetors for a S-T project.
My question is why are Weber's fetching $5-10K on Pelican when your able to buy a complete set of 46PMO Triple Throat 46mm for a 3.2 new for only $4,300 including intake manifold. Also, what's the difference between Weber's made in Italy, Spain or in the Eastern Europe countries.
Because it makes me Happy
The market is not rational.
If it were, people would be buying Honda Civics that can trounce early 911s. You're referring to the 46IDA Webers at the high prices, and they were used on the 906, 911R and a handful of other very limited production cars. so: rarity and genuine-ness make them costly.
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
Crusty Conservative
Just a bit of background, not justification for prices, by any means. Some years back (10-20 or more) the Weber group in Italy closed down production of all the 3 Venturi carbs, and moved the rather worn out tooling to a factory in Spain, later, I guess it was moved again to Eastern Europe somewhere.
Collectors and those who prize originality, value the made in Italy Webers over the layer ones. You can see the Made In Italy on the float bowl sides.. Just be glad you don't have Ferrari Boxer, which needs 4 off these!!
Bill 69 911 T Targa, 2.4E w/carbs (1985-2001) 70 911 S Coupe, 2nd owner (1989- 2015) 73 911 T Targa, 3.2 Motronic (2001- ) |
I just saw a set of early 911 seats with an asking price of $5900 so its not just carbs.
__________________________ '18 Macan S - my turbo Porsche previous Pcars '58 356A coupe, '00 Boxster S;'95 993 Polar Silver/Chestnut;'08 Cayman S;'70 911E |
Quality was much poorer on the non Italian webers. We purchased several sets back in the day, and the Throttle bodies were so bad it was impossible to tune them. One thing to be very careful of, is that the throttle shaft and shaft bores wear out very quickly on these carbs, so buying a used set is risky, especially at today's prices. Throttle body re building is expensive, and to do this properly requires specialized tools and a flow bench to test after the work is done. According to Pierce Manifolds, who rebuilds our throttle bodies, it was not in common for the throttle bodies to be significantly worn by thirty to fourth thousand driving miles. This causes excess air to be drawn in there, which can cause a lean mixture on some barrels and spitting back through the velocity stacks
1969 911TR lightweight, 1850 lb. 245 HP 2.7 short stroke 1973 1/2 911T S optioned sunroof coupe (in progress) 1998 993 Carrera Cabriolet PSS10 lowered E88 cup wheels 1999 996 Carrera Cabriolet |
911 rookie
i sold a set of 46's in 30 minutes for $4300 3 years ago. Probably worth more now but I don't think I will find another set. Sport Seats are in the same catergory.
