Need COA help. Anyone?
I need to verify if numbers are matching on a car.. But don't have a month to wait for the COA from Porsche. I used to know someone in Germany that was able to obtain the info right away.. Unfortunately, that contact is gone. Does anyone know someone who could get me those numbers quick? I would pay for the services of course. Thanks.
Old 06-25-2015, 07:09 AM
Troll Hunter
I think you might get a better response if you told us what year, model etc.
1978 SC Coupe, Gris Argent Metallic Silver
1988 FJ62 Blue/Gray
2020 M2 CS
Old 06-25-2015, 08:43 AM
These guys in France are good and quick and cheap - only works for cars after 1981 though:
Porsche Option decoder VIN
Click on the british flag to get semi-english
Go to "decoder porsche"-->"decode vIN" -->"vin+option(paypal)"
Other than the actual build options, I don't think it will give you the actual engine serial number, just the engine and transmission codes (mine were just M65.07 and G50.20). If you contact them directly they might have more info.
Old 06-25-2015, 08:57 AM
Rescuer of old cars
Arne2's Avatar
Just call PCNA at the 800 number and ask them for the numbers and options for a car you are looking to buy. You get the same info as comes on a CoA over the phone for free. That should take care of the short term need, you can order the printed version later.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 06-25-2015, 10:14 AM
gearhead
I was under the impression (from posts in the tech forum) that they will confirm whether or not the engine and transmission numbers are original, but if you don't supply the numbers, they won't dislcose them. Did I misunderstand?
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 06-25-2015, 10:25 AM
Unfortunately, I do need the engine and transmission serial numbers.. But thank you for trying to help.
Old 06-25-2015, 10:26 AM
gearhead
Give me $5. I will tell you what engine type number and transmission type number belongs in your car. I'll even tell you the start of the serial numbers. That stuff is easy. It's the end of the serial number being matched to the specific chassis that isn't.
1974 914 Bumble Bee
2009 Outback XT
Old 06-25-2015, 10:27 AM
Just called PCNA and yes, they will only verify the numbers. Either yes or no. And that's all I wanted. So thank you Arne2 for your help. Much appreciated.
Old 06-25-2015, 10:33 AM
Rescuer of old cars
Arne2's Avatar
Odd. Last time I called (in February this year), I gave her the VIN and told her I was considering a purchase, and she read off to me the entire bit. Engine and transmission numbers, color and interior codes, and all options.
But still glad that you got the info you needed to move on.
2018 718 Cayman 2.0
Old 06-25-2015, 10:37 AM
techweenie's Avatar
I can get it. Have to pay someone off, so a bit more than a CoA. Not worth it unless the car is pre-70 in which case a Kardex is available.
techweenie | techweenie.com
Marketing Consultant (expensive!)
1969 coupe hot rod
2016 Tesla Model S dd/parts fetcher
Old 06-25-2015, 10:58 AM
Yes. I just used them to get the option codes that were associated with a VIN that I supplied. For that they were accurate and fast.
Old 06-25-2015, 11:35 AM
