-   Porsche Marketplace Discussion (http://forums.pelicanparts.com/forumdisplay.php?f=268)
-   -   Rust Free! ...Ahem (http://forums.pelicanparts.com/showthread.php?t=884907)
techweenie 10-08-2015 04:16 PM
Okay, but if the rusty parts are cut out, leaving only unrusted sheet metal, isn't that okay? Some advertisers think so.
http://forums.pelicanparts.com/uploa...1444346169.jpg
afterburn 549 10-08-2015 04:31 PM
For those that do body work , we giggle when we hear the term "only Surface rust".
Once started it only eats in further from the surface.
Once rust starts, it is in quarantine , or arrest till it gets a opportunity .
SilberUrS6 10-08-2015 05:05 PM
Originally Posted by nota (Post 8827965)
fire creates heat that speeds the combustion reaction
ash does not create more ash
but rust creates more rust , WHY?
rust is a local reaction catalyzed by something at the reaction location
I think there is bio-active something going on
Biogenic Magnetite Formation through Anaerobic Biooxidation of Fe(II)
Project – Super specialized Bio-active surfaces - Projects - Danish Technological Institute
https://www.biooekonomie-bw.de/en/articles/news/mineral-forming-bacteria-of-great-usage-value/
quote from link
"In an iron- and silicate-containing solution, green sulphur bacteria, purple sulphur bacteria and purple non-sulphur bacteria are able to oxidise iron (II) to iron (III) compounds at 20˚ C. One representative of these bacteria, Rhodobacter ferrooxidans, was not discovered until 1993 and it was several more years before further papers were published on this bacterial species. In Tübingen, the bacterium has become a kind of pet project for Kappler's team of researchers. The findings obtained with R. ferrooxidans are a geobiological and geomineral breakthrough, and are so important that they will be included in fundamental science books. "The results open up a completely new understanding of early earth development and the ‘evolution' of atmosphere and hydrosphere," said Kappler.
If you actually read what you're quoting here (and understand it), you'll understand that what you're citing doesn't support your claim.
SilberUrS6 10-08-2015 05:11 PM
Originally Posted by nota (Post 8828140)
s
and the O as in oxidation
needs to be there
so truly anaerobic NO
WRONG. Redox (look it up) reactions do NOT require oxygen to occur. All they require is two compound with different oxidation potential. Ever hear of galvanic corrosion? That's oxidation in which two thing in contact with one another have different oxidation potentials, and a reaction occurs. In the case of anaerobic oxidation, sulfur is often the oxidant. So, YES, oxidation can occur in an anaerobic environment.
Look man, I'm sorry that you don't know much about science, but my chemistry degree didn't come out of the back of a magazine. Rust isn't "alive", and doesn't require anything biological to occur.
pmax 10-08-2015 05:31 PM
You're missing a biology degree.
SilberUrS6 10-08-2015 05:36 PM
No, I'm not.
Mick_D 10-09-2015 08:23 AM
Let me google that redox thing for you:
Redox Reactions
At no point does the oxidation process require OXYGEN.
Oh all right, I will quote:
"An oxidation-reduction (redox) reaction is a type of chemical reaction that involves a transfer of electrons between two species. An oxidation-reduction reaction is any chemical reaction in which the oxidation number of a molecule, atom, or ion changes by gaining or losing an electron."
It's MAGIC, man!
jeffbottman 10-10-2015 07:53 AM
On the flip side, a car like mine that spent its life baking in the desert southwest now needs every baked rubber bit replaced ... I guess that's better than rust.
SilberUrS6 10-10-2015 11:00 AM
Cheaper to fix, maybe, but that assuming you can get the rubber bits. Nice thing about steel, you can find that anywhere, and welding and forming it just takes money and time. Getting NLA rubber is a serious drag.
Mick_D 10-10-2015 01:42 PM
Try finding the tail rubber for a 75-77 Turbo tail sometime.
Mick_D 10-10-2015 03:04 PM
No it isn't. Carrera tail rubber won't fit. Tea tray rubber isn't the right rubber.
pmax 10-11-2015 04:20 PM
Speaking of rust ...
http://forums.pelicanparts.com/porsche-912-technical-forum/884756-well-shes-home-now-what-do-i-do.html#post8831662
plexiform 10-11-2015 05:35 PM
The only logical next question is: If rust is alive then does it have a soul?
SilberUrS6 10-11-2015 05:41 PM
It's not alive, and has no more soul than a fingernail clipping. But I think we'r headed into PARF territory on that one.
Mick_D 10-11-2015 05:47 PM
Maybe the new X-Files reboot will have an episode about rust being alive. It could happen.
plexiform 10-11-2015 05:52 PM
I was being fesecious. I'm quite certain I never learned about the living rust organism in grad school. Dare is ask what PARF stands for? To get back on topic though, I do agree the term "rust free" is entirely abused and overused. I found that out the hard way with a recent episode involving a 75 911 with steel wide fenders.
SilberUrS6 10-11-2015 06:01 PM
PARF is the forum here on PP where logic and intelligence goes to die. Don't go there, it's a silly place.
And yes, I was also a little tongue in cheek, just playing along. You are correct - rust-free really has no meaning these days. It's just ad copy.
kitesurfer2 10-12-2015 01:17 PM
Simple. "Rust free"-
Means; You pay for the car and get the rust free.
