For 1975 the 930 gearbox was released. But in order for homologation they needed 400 road going cars to qualify. At 260hp, the 3.0l turbo street car didn't actually require the new gearbox. Keep in mind, the 915 wasn't even introduced until the 911ST started hitting 250hp in NA form. Carrera 3.0 RSRs of the era were 300hp cars and did just fine in the 73 and 74 race seasons with the 915. It was the turbo racecar that mandated the gearbox change. As for the G50 NA gearbox? There's not as much difference as people think. Internally the gearsets are IDENTICAL on a G50/01 versus a G50/50. The NA box has a 7" ring gear, whereas the turbo has a 9", but it doesn't really matter that much. We've built 1000hp cars around the NA gearbox. When Eddie Bello blew up his G50/52, he put a G50/03 gearbox in the car. He made 1200whp on his car. Given how much better the shifting is with borg-warner synchros, I would take a G50/01 car over a 930 car any day of the week. Ruf agreed and was putting NA gearboxes in their cars a couple years prior to Porsche putting the 50/50 into the 930 in 1989. Over the years, many people have put turbo engines into cars and kept the 915 gearbox like puddy's car. If it's a stockish 3.3l why not? At 304ft/lbs, I personally wouldn't stress too much about it if it's driven maturely. rarly8 and others around here have driven these kinds of cars on the street and track for many years without incident. |
Is that like having a hot girlfriend you can't touch ? |
Do these all end up with a 915 or G50 tranny because those converting these cars are trying to keep costs down? Or is it because they all actually prefer the gearing of a 5 speed tranny? I guess that’s the question... |
Pretty sure you're an outlier, JM. Most prefer driving with a five speed.
OR, you put a 3.3 swap into an 87-88 3,2 Carrera that already has a G50. Or, and here's where the cost and hassle comes in, you have to put G50 torsion tubes into a 915 car to make the gearbox fit. When it comes down to it, doing a gearbox swap on a car that is getting a turbo engine added isn't a simple affair in most instances. Plus there is the 5spd thing. As was mentioned, most people prefer 5spds to 4, and see putting the 930 gearbox in the car a downgrade even though it's stronger. |
If i'm going to keep the car, as per my AMAZING wifes wishes i'm going to have to go for bigger horsepower and upgrade the tranny. Does anyone have a simple 930 swap list they can link, showing what is required?
I have a 1975 chassis with an 915/68 gearbox. Would a SBH 930 fit right in and use my existing axles? I understand shifter and link / rod would have to change. Does clutch cable remain the same? |
This one is a steal. It's got $7000 worth of my parts in it. I think he's got the year wrong because it has continuous bosses. It could be shortened.
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1007685-1983-930-4speed-close-ratio-trans-guards-diff.html#post10186014 EDIT: looked it up. It's an 87. |
http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/1006645-fs-porsche-930-sbh-transmission-lsd.html |
I really don't get why I'm so in the minority preferring the 4 speed over the 5 speed. It's less rowing and more enjoying! Isn't that what Porsche eventually evolved to? Less manual movements for efficiency and effectiveness (and enjoyment). To me, the 4 speed is the best of both worlds, it allows you to row through the gears yourself, but it also allows you to enjoy driving without being held hostage to shifting gears so often. I also prefer the softer clutch pedal as well, so that's another thing. I prefer my leg workouts coming in the gym, not the car. |
I really like the 4 speed box, for the reasons you mentioned - add some power, and a turbocharger that is earlier spooling, more linear, and pulls harder and the wide gear spacing becomes a non-issue, too (for those that often mention the gear spacing to be a negative). Hey PullinMyPuddy, Brandon/quattrorunner did the 930 gearbox conversion within the past couple of years - reach out to him and I'm sure he can give you some direction and/or some tip(s), just the :eek:, on that. |
OK, fellas you're making me a believer in the 4 speed!
I"ll reach out to Quattrorunner. |
If you want a stock 282 hp motor, than as Matt has pointed out, either of the NA 5 speeds will be fine. So it really depends on whether you want stock turbo or modded turbo imo. Once you make that decision, then go from there. That's my two cents... |
For my 5 speed with the short 1st gear I dislike, how much work is it to lengthen that gear? Or is it a bigger project than that, needing to address all of the gears at the same time? |
That 1.83 is super popular in vintage racing because it goes to 67-70mph depending on redline and tires. You would use a 1st gear like that in the International Horseshoe at Daytona or into a lot of slow hairpins around the country. Doesn't even require a high powered car for it to be useful in that situation. Whereas someone running standing mile or 1/2 mile races might find even the 1.83 too short. I make firsts all the way up to 1.600, which is really a 2nd gear ratio in most instances. These are guys who would be changing 2 or 3 gears and maybe even all 4. Changing out first on a G50 is expensive because first is on the mainshaft. So you can't just buy a gear like you can on a 930. One of my tall mainshafts runs $3k plus $1000-1200 in labor to install. That's bench time. It doesn't count R&R from the car. The 3.154 ratio that would be coming out is popular and is the same as used in the 964RS. It would be an easy resale in good used condition, but is generally only worth $1000+/- You can still get them new for around $2k, |
| All times are GMT -8. The time now is 01:54 PM. |
